五月中旬前后吧,Matt Cutts就已经对外宣称,企鹅要升级到2.0了,这次的升级大机会更大。( [- m& R- [; I1 R
g: g+ Z0 r7 D" A4 U$ y( Z下面的这个篇文章虽然有点软文(买软件写得),不过思路还是很值得思考的,所以,推荐给大家!
; m/ n) B2 W: u* E
4 o' o% _9 i* w$ j! j英文不好,能看到,但是翻译肯定没戏了,也希望英文大牛们比如@haichao 能够翻译,当然看看有没有价值。
# t0 n2 d7 A2 ]/ B3 h% D- V8 @% t2 I' z7 w
"Penguin 2.0 … will be much more comprehensive than Penguin 1.0 and it will go deeper and have a larger impact than the original." Matt Cutts
/ X8 x; H* r/ M. nAnother version of Google's major Penguin update is coming in weeks! That's now clear and officially confirmed, putting many webmasters and SEOs into panic again. The previous Penguin update (launched April 24, 2012) has shaken search results, affecting not only black-hat, but also some legitimate sites. And the coming update, Google promises, is going to be even harder. Not to get hit, you have to take anti-Penguin actions now, and that is why today we've tried to gather for you the most actionable advice on how to get your site ready for Penguin 2.0 and how SEO PowerSuite can help you survive the update unaffected. 8 ~. R5 u1 @( S1 |0 o. Y. T
Analyze and clean-up your link profile
# G: `2 w7 U* o) y8 h) B/ T: X% H. uFirst and foremost, Penguin update combats spammy and low-quality backlinks. The new Penguin version is expected to use even more sophisticated techniques to spot spammy links in your backlink profile, so even if your backlinks seem quite OK for Google right now, you'd better run another thorough audit before Penguin 2.0 arrives. So the first thing to do now is to analyze your site's backlinks, identifying any potentially spammy links and getting rid of them before the update. The basic rule here is to avoid backlinks that: Come from sites built exclusively for the purpose of SEO. Use overly-optimized anchor text. Come from adult or other "bad neighborhood" websites. Come from sites that are irrelevant to your own.
8 q9 j0 i9 v0 R0 V7 i- Y) F; Q& g' T) b
Now here's how to find and identify suspicious links pointing to your website. This may take some time, but recovering from the update will for sure take you much longer. & E4 c# s0 Q, Y/ Z* P8 e2 _: |
) x; l' ~" l7 X) x# x- j
Important note: The steps below show how to run backlink audit with SEO PowerSuite's SEO SpyGlass, but in case you're using the software in its trial mode now, your analysis will be limited to 1,000 backlinks only. This means you can potentially miss out on numerous harmful backlinks in your profile. To run the full backlink audit you need a Pro or Enterprise software license: ' P. g o: i$ N( j7 [! x
4 k- i, q2 T6 v+ c- \6 nGet SEO PowerSuite license
& l9 ]' @. R$ x: c _ m; B5 X9 P, D4 B$ ^. ^
+ _9 }5 H# b/ v5 K/ S* r
+ \4 ]) d6 g8 @% |1 w1. Build the most complete list of your backlinks
* b; r% }9 {4 c' t" X! _1.1 Launch SEO SpyGlass, and create a project for your website (or rebuild your current project to have the freshest backlinks added) ' ?: h1 L3 A ^
3 X4 w4 D: n. x- ~1 W0 {+ D
" k' j. n7 g& k! R1 b! D" H
, s$ B# _! b5 }5 N1.2 If you have your own list of backlinks, you can import them into the project in CSV file. File -> Import -> Backlink Data SCV file
5 E) B/ l7 v2 D( f$ V: f* E' i( r- l. Q: S2 F! ]' n c
6 a2 [9 C! r7 f; q
1.3 If you wish to import your backlinks from Google Webmaster tools, you can also do that here: File -> Import -> Import Google Webmaster backlinks
1 l" ?6 Q4 b( D. B! J8 Z" A. V% j% G4 [1 b6 p1 v
; T! G# c& E' @7 I/ R3 h7 T5 e1 p- R* E" b
" \5 n9 k8 b+ n! x& h3 w' ?% U% x- G& d1 v
2. Remove links that no longer exist
8 C0 p* N |" B+ B0 U- V- x4 P+ d# }Search engines are not very quick to update their backlink databases, that's why some backlinks that no longer exist in reality are still kept in their indexes. Thus, when you check your site's backlinks according to Google, for instance, you have some non-existent backlinks messing up in your backlink list. These links can't affect your site in Penguin update, but simply waste your time on useless checking and analyzing. There's no way to get rid of them if you're running your backlink research with an online checker, but SEO SpyGlass can help you here. The tool visits each backlink page real-time and checks if the links are still present – this way you won't waste your time analyzing non-existent links. & A- ~9 R) J& S9 T0 I
R0 P7 M7 H6 U4 Q0 {& v2.1 Choose Update all backlinks option
9 K- c5 {' V6 F- l4 E
& D4 d$ b) p0 x1 y4 o, Y: I- {- _3 A: O; n3 U6 N$ O! ^
2.2 Choose only the Page info factor to check
% Z* j* B* O4 O4 k6 o8 R
: r8 g3 J) U/ T6 T+ m3 u) |. p0 Q5 e5 x2 l; Y& Z4 H
/ a% L1 E: v" [# U. Y$ v
7 B B: P4 k6 w; f
4 P+ M8 O u; @- M. f0 v6 O* a
2.3 Now select all backlinks having a No parameter in the Links Back columns and remove them from your SEO SpyGlass project to focus on the actual backlink only. 9 z: d9 H; L6 _9 n: b2 I8 Y
: z; ?: Q- L3 ~# R
3. Spot and mark any suspicious links in your profile2 r! d- h0 I# S% f7 F9 C
Now you need to spot any links Google may consider spammy and low-quality.
, d5 t% D- v0 V! @# |1 Z0 A/ s( \
3.1 Choose Update all backlinks option again. The factors to check now are: - Domain IP
- Domain Age
- Domain Google PageRank
- Alexa Rank
- External links for page, [' H2 c, H! p1 Q0 y
2 C3 k- @+ x5 _( |' i6 u
9 Y. F& d. e* F' g& [ s
! f, u. _7 E+ O& L2 ]* w* d7 q3 ?# r- N2 Q' k
3.2 Now find all links that Google may consider law-quality, and mark them with tags to get back to them for a closer analysis later on. 1. Group your backlinks by domain, and tag all
4 q+ T: K. G$ ~; z8 g# c+ f+ V
% s: ~0 \1 a5 b. s Site wide links " Z5 }* X1 R2 v# l- ~
`( ^& |1 l! q# y: ` 2. Sort your backlinks by Google PR column and mark the links from domains with* y0 S/ z8 h/ v) q" V! p t% r
1 J9 K/ O0 P* r$ Y+ _
Very low Google domain PageRank ( <1)
3 U2 M- ]$ o4 [( h, J
4 C6 b, |+ X! b' n& |4 s+ |+ T 3. Sort links by Domain Age column and tag links from3 s$ k- h* Y* D
6 w: V$ D5 ~ L
Very young websites (< 6 months old) ' r1 L4 a- K8 D7 K2 Q
) y0 k# Z D' S1 T& U" } 4. Sort links by Alexa Rank and tag those coming from domains with
" g' j; ^+ H! e& E4 J$ l! L5 L- _3 A
Very high Alexa Rank ( Alexa >7,000,000 ) 6 n7 n3 I7 _4 w$ H
, X& E$ o# p: h1 q
5. Sort links by the number of external links from the abcklink page. Tag backlink pages with5 o0 u+ {* y0 w. x0 L0 d, u
V3 D$ m8 C8 @. P+ q6 g! _
Many external links from the page (>20)
% `7 h- `; T/ Y3 n! _+ o% a0 w! l7 C J. {& |, T7 C2 Z3 B" C# O
6. Finally, sort the links by Domain IP and mark x) C5 V. G* @/ o- i
3 k, O7 f1 u2 _5 _5 p7 i
Links from websites with identical C class
' v5 n( m& w3 R' {(the first 3 digits in the IP address)
0 j' N- m. Z7 h
6 t( T7 U8 b2 a1 L4. Find links with suspicious anchor texts o8 B4 T% A9 `/ g* \( ]2 V8 r/ o% v; N$ B/ e
Another point Penguin is likely to focus on is how diverse and natural your link anchor texts are. Too many links with one and the same anchor can put your site in huge Penguin troubles, so now you have to take a closer look at all anchors used excessively in your backlinks profile.
3 ? m# G/ n7 o4.1 Switch to the Statistics section and pick the Anchor texts tab. * a3 }% Z- I4 j4 P5 R( O
& K, X, C: K) N! r/ M! K N2 u
* [. c% E0 n* C- [6 e% E6 W
4.2 Look through your anchor texts and create a list of all excessively used anchors.
- l9 D! J. P! L: U, b: r1 ^& p! c q' G. V6 Y% M
5 h, z5 B0 V- Z/ i) j$ J
+ g( {6 M& c) P! K6 |7 ]1 s* K( F* `- X' U4 B9 R7 y4 j q
* |: U2 ^( A0 Z+ \2 F+ ^" }7 U8 x# P
4.3 Back to your main working area, sort your backlinks by Anchor texts column and tag each link having an anchor from the "excessively used anchors list" you've created.
, v) G- J/ m- k3 D% d
' r: l. j, K6 y) A2 S$ P 5 R' p, {' X+ W; g
5. Check suspicious backlinks manually
- C2 U9 S+ D; p$ M4 ^7 S3.4 Now that all of the suspicious links are detected and marked, take a closer look at each of them. Make sure the websites are relevant to your topic and do not seem a low quality spammy environment. Make sure your anchor texts look naturally and so on. It's up to you how "strict" your backlinks cleaning-up is to be, but removing lots of backlinks at once may cause a ranking drop, so it would be wise to get rid of your links in the most "glaring" cases only. 1) If the backlink you check seems quite OK, remove the "suspicion" tags you've placed for it in your SEO SpyGlass project. 2) If you plan to remove the link, leave the tag in place. Remove the "suspicion" tags for the sites you find OK.
( k! \" a6 r; E9 I2 K6 u6 r6. Contact the webmasters for link removal
6 Y( d' a. n8 X8 J, H+ FNow as you have a list of backlinks to remove, contact the domains' webmasters and ask them to remove the harmful links. SEO SpyGlass will help you find the webmasters' contacts: just add the Contact Info factor to your Preferred backlink factors and update it for the tagged backlinks. ! S1 B* D4 E/ e6 O
2 G3 m A! W7 r
Now send each webmaster a link-removal request and check that the harmful links were removed and no longer spoil your backlink profile. This is it – your backlink audit is done and you can rest confident none of your backlinks will trigger Penguin troubles!
; [/ S/ @( v# ]0 s# U* pOkay, what else can you do?Backlinks are the biggest part of the Penguin update, but don't forget some other things that can destroy your website credibility and rankings: 7 n) [7 l$ u U; _- t: ]# [ R
Eliminate keyword stuffing and duplicate content issues; O/ C3 k4 \; d; I
- Eliminate keyword stuffing issues: calculate the ideal keyword density – the one used by your currently top-ranking competitors. If that technique lets your competitors rank top, than this is the key to creating what Google sees as relevant and non-spammy content!
- Eliminate duplicate content: make sure all of your pages have unique titles and meta descriptions (rewrite any duplicates you find), and use robots.txt file to hide from Google's eyes any types of duplicate pages.9 f/ }7 O7 \. ~5 z- j( s
: w- u' u( m0 S- Q6 |
7 c" \' M1 q6 C' l
Keep track of how your and your competitors rankings change$ g F0 w4 ?4 A) D$ N- j5 U
You can use your Rank Tracker from SEO PowerSuite. - Keep the closest eye on your rankings to instantly react on any changes in your positions.
- Monitor your competitors' rankings ups and downs to learn by their mistakes whenever you see their rankings drop.! y1 _- k* n7 x0 c# o1 L
) o W/ j5 H2 }% M1 U0 S) S: t
8 _$ T6 l) H n% T1 R" |7 Z. |0 {7 nAnd finally… Don't panic!Just like the SEO world is getting mad about Penguin today, it was agonizing over Google Jagger Update back in 2005. Before Jagger, there was Florida. Over the last 10 years, Google was supposed to ruin SEO no less than 6 times. None of the SEO apocalypses ever happened, so why on earth would it happen now? Don't fly into panic, learn from SEO history and… Just keep your website matching Google's quality standards following these tips.
# }7 D, W+ A7 P" Y/ t$ L u5 u' S8 z- ]; y
原文地址:
. C* V# ?- |& n9 v- Xhttp://www.link-assistant.com/news/new-google-penguine-update.html?icf=email
9 Q$ v9 Q9 N3 R2 O4 [! G* w* }2 a. X m" ~0 J2 t0 i. ~
之前分享了SEO PowerSuite的套件7 C% D' X' x8 j5 ^; R
% w% _ ~, v; {- g8 F+ S% }大家可以到:http://www.eefaq.com/thread-103669-1-1.html搞定破解. e% F# C! I* z
o, h- |$ W8 Q* b& _2 N3 s
/ `5 l0 w& u0 m# |希望对大家有所帮助吧。
2 b W4 \9 E% y. O
}& ?. ]4 Q: Y( ?3 @' X' P5 _8 [ b
0 \4 S: p) S0 M- h/ V1 R' N' z8 f1 R5 s' ~8 W1 j0 d! N
( }+ I5 R0 y: {! [- I5 S, F `, n) i
2 W7 r% r* J7 Q i0 i' T
补充内容 (2013-5-22 09:46):
$ s3 E! b8 _7 G$ L1 a6 Q过了五分钟了,不能编辑了,本想把没用的链接去掉,看来晚了。 |
