查看: 565|回复: 7
请问ebay除了CJ可以申请还有哪里可以申请啊?
发表于 2005-4-27 11:23:49 | 显示全部楼层 |阅读模式
如题,谢谢指点。: )
发表于 2005-4-27 18:18:58 | 显示全部楼层
 楼主| 发表于 2005-4-27 18:53:41 | 显示全部楼层
谢谢静水,CJ是不是每个月底K账户啊?是认为ZB K账户还是被广告商投诉才K 账户啊?
 楼主| 发表于 2005-4-27 18:59:59 | 显示全部楼层
刚刚证实了:
The purpose of this letter is to inform you that your publisher
account has been removed from the CJ Network and your earnings have
been reversed ("charged-back") from your account and credited back to
the relevant advertiser(s). This is the result of non bona fide
transactions identified by the latest audit performed on your
account.  Non bona fide transactions include false, self inflated,
and/or duplicate leads or transactions.
You are not eligible to rejoin the CJ Marketplace and any attempt to
do so will result in immediate termination and reversal.
郁闷~~,账户里的钱会发吗?
发表于 2005-4-27 19:10:40 | 显示全部楼层
不会给了
 楼主| 发表于 2005-4-27 19:39:45 | 显示全部楼层
晕死~~是因为广告商投诉还是被CJ 认为EMUK 了?
发表于 2005-4-27 19:51:02 | 显示全部楼层
不知道,应该是CJ认定的吧,EBAY一般不投诉的.如果是LS有EBAY他就给了.可惜没有.
 楼主| 发表于 2005-4-27 21:38:48 | 显示全部楼层
郁闷啊~~还有什么联盟可以申请ebay 啊,CJ 查得太严了
GMT+8, 2024-11-22 09:36
