查看: 1280|回复: 0
翻译贴:你不知道的FB小技巧
发表于 2012-10-31 10:19:59 | 显示全部楼层 |阅读模式
FaceBook Tip you dont know
你不知道的FB小技巧
原贴地址:http://advertcn.com/viewthread.p ... 26amp%3Btypeid%3D18
If you plan to create accounts for re selling them later you will need to handle them to your buyer. This will probably block the account (image verfication aka pain in the arse)To avoid that tell them to use the same proxie as you. I mean the same City. Same country is not enough.This is one way. The other, easier is to NOT accept friends requests.Basically you handle the account with NOT ACCEPTED friends requests.No roadblock should occur. They log in from any IP they want, accepts requests and all are happy.FB dont care cos the account have 0 friends - they treat like a new.
如果你打算在FB建立一些帐户,日后售出获利的话,在和买家交易时也要注意一些问题以免帐户被封
你的买家最好和你使用相同的代理,我意思是你们要显示在一个城市,仅仅一个国家是不够的
这是一个办法,还有就是不要接受添加好友的任何请求,这样交易不会有任何问题,FB不会在意的,看起来这就像一个新的一样
GMT+8, 2025-4-12 23:18
