查看: 1592|回复: 9
求助下。。CJ里的佣金到底是广告主没支付还是CJ没支付啊
发表于 2012-11-14 03:00:24 | 显示全部楼层 |阅读模式
1e币
专门这个点没睡觉 给CJ 发邮件
CJ当初看个帖子说什么支付RMB支付啦 结果注册了RMB账号
现在好了根本RMB支付想都别想了。
以下是个图
Beginning Balance
Commissions
确切的意思 。。
最佳答案
查看完整内容
Beginning balance就是账户上过去已经有的钱了,commission部分是最近新登的钱。这两种都表示,广告主已经支付了,已经到CJ的账户上了。 CJ发钱一般在每月的20号左右了~Good luck!
发表于 2012-11-14 03:00:25 | 显示全部楼层
发表于 2012-11-14 08:57:06 | 显示全部楼层
Beginning Balance   原来账户余额
Commissions    完成任务后的提成
发表于 2012-11-14 10:10:35 | 显示全部楼层
联系CJ,他们怎么说呢?
发表于 2012-11-14 11:47:16 | 显示全部楼层
你最低支付设置多少?
 楼主| 发表于 2012-11-14 12:55:12 | 显示全部楼层
回复 4# ledgiftsworld
  1.     Hello
  2. It appears that the majority of your commissions were generated by bebe.com. It appears that advertiser has a negative balance at the moment.
  3. Unfortunately Commission Junction cannot pay publishers until the necessary funds are deposited and we indicate this specifically in the Publisher Service Agreement that you agreed to when you signed up for your Commission Junction account:
  4. PSA Section 3(e) states: “CJ shall have no obligation to make payment of any Payouts for which CJ has not received payment from the relevant Advertiser of all monies due to CJ (including for all Payouts owed by such Advertiser to all of such Advertiser's Publishers).”
  5. If the advertiser brings their account current by next month’s payout you should see these commissions move from “locked” to “closed” and payment will be issued.
  6. For more information about the payment process, see the following link.
cj说广告主 负平衡?还没给钱 是这样吗
发表于 2012-11-14 13:58:31 | 显示全部楼层
    好像只回答了Commission的问题,你原来的 beginning balance钱为什么不支付,对方没说。\
你再询问一下了,如果仅只是commission的问题,让CJ先把你的beginning balance钱先支付过来吧,早点拿到钱早安心。
备注:beginning balance的理解是参考3#的朋友回复的,我是新人,对国外网络赚钱的许多名称不太清楚
 楼主| 发表于 2012-11-15 00:28:11 | 显示全部楼层
回复 2# webabc
    这种情况2个月前就有了 CJ就是RMB不支付 所以我都停止做RMB账户
发表于 2012-11-15 08:50:58 | 显示全部楼层
回复 8# vagaa
这一段解释了付款的流程。你之前显示在balance的钱,按照这个付款的流程,就表示之前广告商是给钱了。只有locked-->closed之后的钱会表示为balance的。
不过你做的广告商现在账户是负值。Balance是表示账目、账户余额的意思了。
你应该再联系CJ解释下你的情况。
 楼主| 发表于 2012-11-15 12:34:15 | 显示全部楼层
回复 9# webabc
    Bebe.com 怎么会负值。很纳闷
今天CJ客户邮件说
Hello ,
I am checking with Finance to see if RMB payouts will be releasable this month.
GMT+8, 2025-4-25 16:38
