楼主: cyrich
一个ClickBank小技巧
发表于 2013-5-7 12:39:18 | 显示全部楼层
 楼主| 发表于 2013-5-7 12:58:56 | 显示全部楼层
yyqslly 发表于 2013-5-7 10:13
为什么不直接用商家的LP呢?
你意思是不做站,直接推aff link吗?
我的跟商家的LP一模一样,其实就是商家的LP
发表于 2013-5-7 13:31:17 | 显示全部楼层
不错的经验
发表于 2013-5-7 13:43:03 | 显示全部楼层
收藏一下
发表于 2013-5-7 13:52:52 | 显示全部楼层
谢谢分享 还没做过cb
发表于 2013-5-7 13:58:01 | 显示全部楼层
直接复制商家的LP  应该算违规的吧?
 楼主| 发表于 2013-5-7 14:11:26 | 显示全部楼层
tonycai7 发表于 2013-5-7 13:58
直接复制商家的LP  应该算违规的吧?
这个不清楚,只要能给商家带来有效sale就行了
发表于 2013-5-7 14:17:17 | 显示全部楼层
还没做CB,以后做
发表于 2013-5-7 14:41:40 | 显示全部楼层
为什么不直接用商家的LP呢?
我告诉你吧,这点绝对是败笔
cb的商家会消失,产品有期限的
等你花了大量力气推销别人的连接,你某天突然发现他的产品下架了,你哭了
发表于 2013-5-7 19:15:09 | 显示全部楼层
有技术含量
发表于 2013-5-8 11:19:29 | 显示全部楼层
這個很實用哦
发表于 2013-5-8 12:57:57 | 显示全部楼层
还没做过CB,学习下
发表于 2013-5-8 17:25:43 | 显示全部楼层
找到了下面的文章,有心人可以看看
  1. http://www.clickbankguide.com/orderlink.htm
Bypassing the sales page
A common request from ClickBank affiliates is a method to bypass the vendor's sales page and link directly to the ClickBank order form.
The reason is that they can write their own sales copy which is obviously desirable if the vendor's sales page does not convert well or allows the visitor to be distracted by external links favourable to the vendor
How to do it
1. Direct order link
Here is an affiliate link which takes the visitor directly to the order form instead of the sales page.
http://ITEM.AFFILIATE_VENDOR.pay.clickbank.net
(there is an underscore between AFFILIATE and VENDOR)
Disadvantages:
    * The normal hoplink takes priority over this link: therefore an affiliate will not get commission if the visitor has previously gone through another affiliate's hoplink
    * The link does not set a cookie: therefore an affiliate will not get commission if the visitor later returns to the site without using that link
    * This is an unofficial link. It is not listed at the ClickBank site, so it can be withdrawn at any time. So use with caution.
参与人数 2e币 +8 收起 理由
ebookyx + 3 有見地
月光飞燕 + 5 感谢提供
发表于 2013-5-8 17:37:34 | 显示全部楼层
关键是这三个disadvantages,大家要留心,我还没多细想,只是第一时间看到就转发过来了
Disadvantages:
 楼主| 发表于 2013-5-8 18:25:43 | 显示全部楼层
发表于 2013-5-8 23:52:21 | 显示全部楼层
好方法
发表于 2013-5-20 18:21:26 | 显示全部楼层
支持楼主的分享了,表示又收获了
发表于 2013-6-28 23:23:17 | 显示全部楼层
很受教育啊,正在做英文项目 刚刚起步,希望能行!
发表于 2013-6-28 23:51:29 | 显示全部楼层
这个分享真不错,谢谢
发表于 2013-6-29 00:16:32 | 显示全部楼层
楼主分享的tips不错,又学到了
CB上的那些数字产品,总有个生存周期,不稳定
不过也有些好产品
GMT+8, 2025-4-12 13:20
