我不喜欢灌水赚T币,网站已经有太多水贴了,影响大家阅读的速度。我也是初建第一个niche站,还在学习的路上,因为T币不足,只能搜索一些有价值的文章来看,感觉好的就翻译出来分享给大家,虽然翻译别人的文章很慢,但有一个好处,就是等翻译完,作者的思想就基本背下来了,印象更深。所以在你看完这篇文章后,顺便给点分鼓励一下,反正给分不会扣减你的T币
( l( T& I+ z1 R9 N, C* P 6 w C/ U6 v1 u. d" [1 p
5 Y: ~( } R: e: B8 c" B0 m, EHow To Build Backlink Pyramid# ~6 j+ d( S: S: H
怎样构建反链金字塔0 N: j0 w) w1 ~0 F0 H1 H
/ C% s' T8 N! G6 i J2 ]( j+ z$ {9 Y& Q* r
Backlink Pyramid is one method or strategy that is very effective in building backlinks (backlinks building). Backlink pyramid shape arguably unique because it provides a direct backlink to your blog. with not too many backlinks but backlinks with high quality. When described, it does have a backlink pyramid arrangement of such pyramid with the website / blog is at the tip / top of the pyramid backlinks.: C5 `. J! M( @, c: {' Q' O# u8 F
7 o( ]8 L5 s( d3 K
反链金字塔是一种非常有效的外链创建策略。反链金字塔形状具有独特的理论依据,因为它直接对你的blog提供了不太多但是高质量的反向链接。我们在描述的时候,的确按金字塔的排列,将网站或blog放在反链金字塔的顶端。
! E( V7 T/ V* u4 D4 _: S3 U2 K
; K+ l3 T/ j& m& ~% c; p& @Backlink pyramid has a scheme that leads directly to your website / blog called layer / tier one. Then, again providing a backlink to below layer / tier one with more backlinks, this section is called layer / tier two. May be as layer / tier three and so on. However, this backlink pyramid with two layers is usually enough / tier only. Backlink pyramid can be drawn using a variety of sources such as forums profile backlinks, social bookmarking, press release, article directories, wikis, rss directory, a blog comment, EDU / GOV, etc.. However, it would be more effective and deliver impact is felt when the first layer of backlinks backlink-sourced from quality backlinks./ r1 g: V/ D) m& ]
# o) |! R F8 K7 A9 {: `% U1 t反链金字塔的结构是这样的,直接指向你的网站的链接层叫第一层(tier one),然后有更多的反向链接指向第一层的链接,也就是第二层(tier two)。第三层依次类推。然而,通常情况下两层的反链金字塔结构就已经足够了。反链金字塔可以通过很多网站资源构造出来,比如论坛个人信息反链、社交网站的书签、新闻稿、文章目录、百科、RSS目录、blog的评论、edu/gov网站等等。不过更有效且能产生直接影响的是第一层反链来源于高质量网站。
1 C9 ^; i% M$ {- h0 S* R. E n* M7 h( g% g
I myself applied the method or strategy backlink building for several blogs trials. The result is quite satisfactory. Only with a quality backlink that leads directly to the blog blogs trials, to boost SERP position several articles to the front page of google.. f3 S# L" P U( G5 [* n' r2 p
$ j+ @# r, Q0 E% X* y+ t# ]
我本人使用反链金字塔策略尝试建立了几个blog网站,效果非常满意。在blog网站测试中,只有当高质量的链接直接指向blog网站时,blog的文章很快就被google排到搜索结果首页。
: u- Q( {0 D% ?: S$ c
" j1 j, E2 N! i3 l3 qBacklink pyramid that I woke up having the structure / scheme is very simple with a depth of 2 layer / tier only. Give a backlink on one layer that is considered the highest quality such as press releases, EDU WIKI, social bookmarking, forum profile, high PR article directories, and comment EDU and GOV. Then on layer / tier two you quality backlinks with the usual (for reasons of easier course) such as blog comments, shoutbox etc. backlinks from bravejournal.com. 7 a. p% w/ L: I7 [
; f; k$ Z" [1 I: a我发现使用2层的反链金字塔结构非常简单,第一层使用高质量的链接,比如新闻稿、edu wiki、社交网站书签、论坛个人信息、高质量的文章目录、edu和gov网站评论。第二层使用普通质量的链接(主要是容易),比如blog评论、留言板、bravejournal.com等。: X, H; r* u) ]0 f
, H1 q$ }& D/ r$ u% R
For the record, must be patient because usually backlink pyramid method will not directly feel the effect in the SERP, have to wait 2-4 weeks.
8 ?+ X8 ?4 B) Q1 n+ d4 x
* o4 c# e# b1 c必须申明,使用反链金字塔不会立即在google搜索结果中生效,需要等2到4周的时间。
5 y; I* [9 I2 u+ `
) {$ f, x" f) t1 @1 ^+ n: e# awhile waiting for the effects of backlinks pryramid. it never hurts to keep updating the post. with the keyword with the tough competition in the search engines. a mean to know the effect of backlink optimization will be undertaken. if it has not been too good effect. build more backlink pyramid with more quality links. as having a high page rank higher alexa rank etc..0 v8 [1 Y* g4 Y' G
: A" v# O z2 a* T在等待反链金字塔生效过程中,不会影响网站内容的更新。想了解反链金字塔的作用的一个办法是使用高竞争的关键词。如果反链金字塔的效果尚未达到预期,那就创建更多地高质量链接,因为它们具有高PR和alexa排名。
, H) f: ?3 M& V5 l9 n; j) U
" |+ x! p/ @# Q A0 Z8 n3 {$ HTo note. to build backlinks pyramid, the blog should already have a age, do not build backlinks pyramid for the new blog. and not be too often build backlin pryramid because the blog shall be deemed spam by the search engines
' K+ ? n0 F& {& {% P- p$ d7 D$ S
, A2 \ l2 I2 h/ p8 i( Q需要注意的是,构建反链金字塔是,你的blog需要有一定的年龄,所以不要对一个新的blog构建反链金字塔,不要过于频繁的构建反链金字塔,否则搜索引擎会认为你在作弊。
, I" j* @2 X% p4 q& @* C% z
( x1 A7 p; L: o/ O6 }3 C# M' b
' c/ S4 L$ a3 O: h- |4 t |
