查看: 1447|回复: 20
amazon官方回信说允许302跳转
发表于 2013-7-24 04:20:55 | 显示全部楼层 |阅读模式
amazon官方回信说允许302跳转,我还是取消掉了302跳转,免得到时候K号就杯具了,反正直链也没多大影响
  1. Hello Leo,
  2. As noted previously, automatically redirecting to Amazon.com is in violation of our Operating Agreement as it infringes on our trademark and it causes misunderstandings with our customers.
  3. As a member of the Associates Program and to earn advertising fees, you must place links to Amazon.com on your web site. The link you have provided in your message,  is following our guidelines and is fine for use.
  4. The reason the links on your page  re acceptable is because the visitor to your site must actively click on a link to be forwarded to Amazon.com.
  5. I hope this information is helpful.
LZ 确定没有看错? 这不是说不能吗?  发表于 2013-7-24 15:40
hudba + 1 谢谢分享!
发表于 2013-7-24 08:49:02 | 显示全部楼层
那你费劲,发邮件给amazon官方干嘛呢
发表于 2013-7-24 09:05:57 | 显示全部楼层
LZ是想确认一下吧,呵呵
发表于 2013-7-24 10:15:39 | 显示全部楼层
没有看到有说允许的字眼啊
发表于 2013-7-24 10:27:37 | 显示全部楼层
automatically redirecting 是指打开网站 不经过用户点击 过个几秒自己跳转到amazon吧
Amazon就是这个意思,用户点击后再跳转是允许的  发表于 2013-7-29 11:33
发表于 2013-7-24 11:13:29 | 显示全部楼层
发表于 2013-7-24 11:18:59 | 显示全部楼层
。。。。。。。。。。。。。。。。。。。。automatically redirecting to Amazon.com is in violation of our Operating Agreement
发表于 2013-7-24 11:36:08 | 显示全部楼层
不知道楼主认识violation 这个单词不
发表于 2013-7-24 12:03:53 | 显示全部楼层
其实要302转发,如果能实现点击转发过程中,动态提示用户,正在转向亚马逊这几个字,估计就不违反了。
就像论坛打开时,有正在加载。这几个字一样。
发表于 2013-7-24 12:30:46 | 显示全部楼层
跳转下就够了中间不要夹杂广告
发表于 2013-7-24 13:01:29 | 显示全部楼层
http://www.toptenreviews.com/scripts/trans_id.php?url=http%3A%2F%2Fwww.amazon.com%2Fgp%2Fproduct%2FB002KCMH7A%2Fref%3Das_li_ss_tl%3Fie%3DUTF8%26camp%3D1789%26creative%3D390957%26creativeASIN%3DB002KCMH7A%26linkCode%3Das2%26tag%3Dttr_car-vacuum-cleaners-20&p_id=56937¶m=&q_delimit=0&ti=28F3518D851D37576000012F600080781374641916166
发表于 2013-7-24 14:53:38 | 显示全部楼层
楼主 你是不是搞错了啊??in violation of our Operating Agreement    是说这样违反了规定啊。
ClD
自动重定向到Amazon.com是违反我们的营运协议,因为它侵犯了我们的商标和它引起的误解与我们的客户。  发表于 2013-7-24 23:14
 楼主| 发表于 2013-7-24 18:14:36 | 显示全部楼层
邮件的意思是如果直接跳转不是符合规定的,因为那误导了访客。但是
  1. The reason the links on your page  re acceptable is because the visitor to your site must actively click on a link to be forwarded to Amazon.com.
acceptable 可接受,正确引导访客到amazon是可以的。虽然英文不好,但是借助google翻译,还是大概能知道意思的。
发表于 2013-7-24 19:26:30 | 显示全部楼层
302了,你怎么让亚马逊认为,是用户自己点的?
明显不行啊。
发表于 2013-7-24 22:48:39 | 显示全部楼层
文章锚文本放自己站的url,点击跳转到Amazon。看到不少niche站这么操作
发表于 2013-7-26 13:13:01 | 显示全部楼层
iamazon 发表于 2013-7-24 13:01
http://www.toptenreviews.com/scripts/trans_id.php?url=http%3A%2F%2Fwww.amazon.com%2Fgp%2Fproduct%2FB ...
这个大神想说什么呢?求指点
发表于 2013-7-26 16:01:02 | 显示全部楼层
微笑2013 发表于 2013-7-24 18:14
邮件的意思是如果直接跳转不是符合规定的,因为那误导了访客。但是acceptable 可接受,正确 ...
呵呵,谢谢二位解释…… 但是还是不大确定。字面的意思是懂的,但是还是不大明白。关于302,这样官方说的意思是真的允许吗?
发表于 2013-7-26 16:36:29 | 显示全部楼层
迷糊了,到底是说的允许还是不允许啊
发表于 2013-7-27 02:44:07 | 显示全部楼层
;P;P
老外给了明确的答复,你们就却看头和看尾,当然头尾都是在围绕怎样使用链接的解答
作为联盟的一个成员并且以此来赚取广告费,你必须在你的网站上面留有链接到Amazon.com。在你信息中所提供的链接(这个必定是楼主提供的302链接),是符合我们的规则并且是可以正常使用的。
发表于 2013-7-27 22:10:19 | 显示全部楼层
我觉得应该是指如果是用户点击的链接再进行跳转是被允许的,意思是说非用户点击就不行
GMT+8, 2025-4-15 14:06
