查看: 1068|回复: 15
关于外链对Squidoo平台影响的探讨
发表于 2013-8-13 10:34:42 | 显示全部楼层 |阅读模式
以下是我5月份的时候针对团队文字编辑在Squidoo平台上发布的文章被locked而分析有感,下面是我通过google查询发现的一些外链对Squidoo的影响的一些探讨。原创内容,详情请看下面内容。" w: g# a) r9 P7 h% o. [1 t- w
( D0 L9 z- g6 L7 D
团队文字编辑一直有在Squidoo平台上发布文章,而技术组也给这些文章一些外链支持。然后后来相继的Squidoo文章被locked,而Squidoo又没有给出明确的理由,都能知道是触犯相关规定,但是不能明确。思索规则之余,我想到都是做了外链的lens才被taken down。所以不得不想到也许外链对其有一定的副作用。/ ^7 F/ U( }+ f& l9 F
只是空想没有证据肯定不足以说明。于是在google上搜索相关内容,经过这2天的搜索查询,终于找到了关于外链对Squidoo的影响一说:详情戳下链接- I/ U! {; j8 Y+ Q# Y9 k/ ]- |
http://hq.squidoo.com/tips/are-the-inbound-links-to-your-lenses-adding-value/- ?% `- b! s( Z# ~+ J
  K% }( H) t; D" P" c5 V( L
SquidooHQ中文章末尾处有提到要保证外链相关性。nofollow的,低质量的外链会对有负面影响。
' j* s( y2 k+ O& U* A2 O8 O' u4 h- o* d$ t$ J# |0 I4 \" q* \; B: k
Make sure that every link added to a lens is targeted and relevant. Avoid cheap linking from places that may not be trusted. Lenses found to contain an excess of links from “nofollowed” blog comments 6 ]3 q! _" |3 T6 |0 _2 a( ^5 `3 l
or low quality “link directories” could be flagged or locked.
- }9 i. ^& ~8 ~# c
1 D( }* l9 p) H3 P- {" D! {明确提到有负面影响,但是对于怎么样算低质外链,多少条算是过量,等等都没有明确的界限。这也是很多人所关心的,如评论中所提到的; m% U6 @  Q  D; F6 y
This really clears nothing up for me,in fact the ambiguous terminology used to "clarify" the supposed inbound link problem which is wrongly punishing & frustrating so many of us lensmasters is actually confusing.& k/ @1 Q7 l4 a/ W
The term "low quality link" does not really tell us much,since we are discussing Google perhaps we should use their ranking system to help us understand better.# q, M2 ^0 W4 T7 G+ {3 b9 o
Is a Pr5 link low quality,or is it acceptable? At what PR level does the Squidoo filter decide the links change from "acceptable quality" to "low quality"?
"Lenses found to contain an excess of links from “no followed” blog 0 F: w6 A$ H( k, p, a0 q8 E
comments or low quality “link directories” could be flagged or locked"-How many is too many?
6 Z) P+ y& Y+ ~( @4 tI have a lens which is (probably) about to be deleted after nearly 3 years of being blessed by SquidAngels and more because it has 6 links from 5 domains and the filter has deemed them to be low quality as of my (attempted) last update. Would 5 have passed the filter? Maybe?
1 J9 Z- O( l: r
6 T( M' |) p- w9 G6 f6 e
不管大家对这个规则有多质疑,总而言之,规则出现了,外链对其有一定的影响力。以下为关于这一规则的解读讨论及建议
- ?' S* z% N4 C! E4 O1.http://www.squidprofits.com/squidoo-filters-backlinks-and-outbound-links/
, s$ T9 q- u* i* C- j* @2.http://www.squidoo.com/squidoo-hq-posts-about-inbound-links-filters
/ e' s& D+ U3 o, Q4 y9 k3 E3 A% J: l3.http://hq.squidoo.com/tips/why-does-squidoo-use-filters/8 i% h& a% c$ w
4.http://hq.squidoo.com/squid-news/changing-link-status-on-squidoo/
- D4 [4 ?/ I. n& p' R6 x5.http://hq.squidoo.com/tips/inbound-links-what-to-encourage-and-what-to-avoid/; S0 Y3 G/ f! `( r  ]2 ]5 ]/ e. E+ W/ j
3 Z$ h7 |. d. e! l* V* W2 e3 V, F# {
6.http://hq.squidoo.com/tips/what-to-do-with-a-locked-lens-and-more-advice-about-content/' t$ B! ^) I5 R( k
; p3 H3 n: B+ q" E$ P) f# [5 \大家都知道SquidooHQ是Squidoo的官方说明,所以外链这个影响都是必然的了。所以个人觉得工具外链对squidoo lens不适用。上面的NO1讨论文章中,有提到这么一句:
" e! b  b( k- T# i6 `
Someone asks – “How can we control who links to our lenses from where? Do we need to worry about lenses getting locked because others have linked to them?” The response?
“No need to worry Kylyssa, we’re not locking quality lenses.”
由此看看出高质量的内容是尤为重要的。
7 }' g% e1 W5 D  D9 Q以下为很明确的一些文字要求的说明
8 ~& V' s# r. E& h) l  lThe most common reasons that lenses get unpublished+ k, `* ?, O( D0 N" D
1The lens is on one of our SquidDon't topics that we can't allow on the site.
5 f, n; g( h( W- H  v* o) L2The lens exists solely as an affiliate program lens, or engages in some sort of article spinning, rather than being original opinion content.% t; O2 P$ m0 g$ J- u
3The lens has plagiarized content.
; _4 i  Y* E( O& J. y4The lens has aggressively duplicated content, and very little original, unique content written by you.
& O' K8 P; E$ o5The lens breaks any other elements of our content policies and TOS, ranging from keyword stuffing, content spamming, redirects, low quality, cloned lenses, hate lenses, lenses that violate our partner's TOS and more.
1 I. l7 m& j6 n( ?; u) n6We determine that the lens or the lensmaster has been doing more harm than good as a part of this community, and therefore the account gets suspended regardless of the content on the lens.
- s' Z/ T3 f. Y! ~: z5 n7The lens is not in English and we cannot support complaints or spam suspicions about it.
& t* s  Q) z3 T7 s
& M5 [5 Y5 Q1 A/ X( K  ]6 R# G3 I& Z上面有明确的提到Affiliate,所以个人建议在Squidoo中不要带AFF链接,最起码的是不要显性的带,隐藏性的可以尝试带看是否会被filter检测出。
# G% Q6 R. Y! J" P) i6 @: s虽然Squidoo不适宜做工具外链,手工外链也需谨慎,但是平台还是可以利用好的,一篇高质量的文章,即使没有太大外链支持,也是能有很好的排名,流量也会很好。" S$ ^. a$ V* l9 U& ~% v
在用于品牌推广或者是Niche的流量文章,都是可行的。因为这些不可控,及其外链的影响,我们对于此平台的精力可能就需要稍微少一些,多挖掘一些别的高质平台。
5 h1 r( N6 T. h2 z. M8 C. B上面的讨论一中评论里面有提到这两个平台:http://www.sirgo.com/  http://www.bubblews.com/ 文章平台,可以跟进。
2 c) h4 a* V1 w9 @  p+ s# k- x3 X: P# b. ]6 [. A
PS:以上探讨只是说明外链对于lens的影响,但是不能决定的说明我们的文章被locked就是因为这个原因。一个第三方平台确实很不可控,我们只能在尽量提高文章的质量上面又去完善的把握在它的规则之中。
- N  H3 [" O/ d- u, r. U4 e' E  Z网上很多探讨Squidoo平台的,当然大家基本上都是在这个平台上去挣钱。正面反面的都很多。具体有兴趣的可以看看,刚刚提到的讨论1.http://www.squidprofits.com的博客,$ r; G2 l+ ^$ ^' ]% ?& y" g) L
: W0 T. o3 v' S6 X, p
下面为知名论坛中对Squidoo的讨论。讨论中也有很多对于Squidoo的其他信息,有兴趣的可以详细戳看。4 {; i% Y" h5 G2 j% K4 r! ]
http://www.warriorforum.com/main-internet-marketing-discussion-forum/731902-site-squidoo-lens.html http://www.warriorforum.com/main-internet-marketing-discussion-forum/702223-what-now-woke-morning-find-my-squidoo-empire-has-been-locked.html
6 F* E+ A( t1 m* y: J- M  w" S" i+ I% a- v, [/ S* w( l. }
欢迎大家来拍砖。
  w  u4 A3 [1 {4 ?5 v4 Z) b$ }" p/ g6 r" }' p- M* X
7 i, U  G5 B  ~3 F
3 v3 w& p( _, M
$ @) w- U& [8 k6 Z- v( j, m+ l6 S. K8 I+ ?/ D
参与人数 6e币 +29 收起 理由
月光飞燕 + 20 有見地
bbhit + 1 谢谢分享!
hoby + 1 有見地
哎呀妈啊 + 2
Terry + 2
adver + 3
发表于 2013-8-13 10:39:12 | 显示全部楼层
squidoo的效果没有以前那么明显了。估计他们也受到来自google的压力
7 c% T% i- h" C7 i0 S
发表于 2013-8-13 11:10:50 | 显示全部楼层
我也是这样觉得的,发点外链,就会被lock掉
7 ]6 d. B  `$ S+ R5 g8 [
5 M/ K$ \, ^( [' F7 I然后把被lock的文章删了,再重新发一次就可以了& ~( E: i1 o- [7 ^8 I7 `6 ~
 楼主| 发表于 2013-8-13 11:28:42 | 显示全部楼层
adver 发表于 2013-8-13 11:10
) q. \7 ?4 D) R9 W0 L8 ^  A我也是这样觉得的,发点外链,就会被lock掉( A! Z) q8 _5 L; h$ o8 W6 U
# G; N7 ~* L: a8 X4 s
' X! S( l; i5 n# E% _2 U这样也行啊~呵呵~我只探讨问题,至于俺的英文水平嘛,是没法在squidoo上面发文章了,当然也从未尝试过。都是有专人来发的。发现这些平台主要还是看原创性。之前在hubpages上面发文章,我直接用翻译了篇中文文章然后发上去,容易就通过了。改写个英文文章却说duplicate,没能通过。% N0 `, a0 c# r2 g' }1 |
: E5 S* `* Z+ ^# H$ a
6 ^  ]# a/ G+ n8 t( |3 F! R
" t( x/ E9 U) S
发表于 2013-8-13 12:40:00 | 显示全部楼层
hubpages和squidoo这类web2.0为什么有人做了对本站没效果呢,究其原因能引出流量的锚文本效果大于0.2,相反就是0或-1。8 P! Q: l, B% q# }
如果想维护这些站,讨好他们的脾气,比专心做内容要麻烦的多的多。; s: i8 {8 L3 @' B
发表于 2013-8-13 20:25:38 | 显示全部楼层
qqqwwqqq 发表于 2013-8-13 12:40 3 p( k3 k7 |5 L* W+ j
hubpages和squidoo这类web2.0为什么有人做了对本站没效果呢,究其原因能引出流量的锚文本效果大于0.2,相反 ...
& R: \! Z6 x' ^# J& I比较赞同。花那么大的精力去维护他们,还不如用心维护自己的小站。。。。
' E7 V; d% q& U7 r; O( _% W
发表于 2013-8-13 21:27:58 | 显示全部楼层
Squidoo的确是越来越难发文章了。站群是越来越有必要啊1 [: s4 l# a9 Z1 E0 {
发表于 2013-8-13 23:06:24 | 显示全部楼层
连这么大的网站都在担心GOOGLE的规则,自然就会给压力用户了
4 T0 R$ `- z4 |
发表于 2013-8-13 23:44:19 | 显示全部楼层
支持原创好文章,继续分享吧# x% t# j4 ~4 Q$ g9 l8 k  k
发表于 2013-8-14 08:42:43 | 显示全部楼层
Squidoo是Web2.0里面很强大的一个站' c0 F/ g+ m9 N& s$ G+ y
 楼主| 发表于 2013-8-14 10:14:58 | 显示全部楼层
hoby 发表于 2013-8-14 08:42
! L5 q+ ^, [, O" d' |6 g& O* n! |Squidoo是Web2.0里面很强大的一个站
( v- k' K1 c3 |+ Y' N$ K, I. r我个人把这个平台偏向属于Article Directory站。因为对于文章要求比较高。还有hubpages也是如此。而一般的Web2.0站,没有这么严格。不过Squidoo确实很强大的说。) A9 _- K' j% P, t4 Y  x
 楼主| 发表于 2013-8-14 10:16:40 | 显示全部楼层
qqqwwqqq 发表于 2013-8-13 12:40 8 Y. _, B" K6 l3 `- B5 r
0 C8 `/ q7 ~6 P. M7 U8 G+ o7 ?
确实啊,这些站点,少量发表就行。专门做自己的小站更划算。! S6 {; o1 ~# z" r- j% }
. x5 c4 w$ j: h
发表于 2013-8-14 10:29:38 | 显示全部楼层
Be what you want to be,not what others want to see.
  g9 X. o/ f, |# m  ]( H' A; A' xBe  what you want to be,and what ours want to see.: U2 Q0 Z& A8 U1 i
U are not only one  in this world!
) r3 `& C; r0 H) U) o' s$ V4 g6 F  t4 U" ]7 K- u3 n6 Q% Y, N9 A5 o
 楼主| 发表于 2013-8-14 10:51:54 | 显示全部楼层
webmastercn 发表于 2013-8-14 10:29 $ A0 o. m' d: G, r3 N' M
Be what you want to be,not what others want to see.& G6 r* l# x' o4 H% Z5 V
Be  what you want to be,and what ours want to se ...
2 C* e4 i6 `" r( ?有见地~现在的状态是,I don't know what I want to be, and didn't be what others want to see.
' I+ m& l& W  r4 C& V6 Z
& r9 ?5 E$ Z- {5 c
发表于 2013-8-14 11:06:15 | 显示全部楼层
Kathy 发表于 2013-8-14 10:51
0 C+ e/ Q: Y5 A9 l# G6 R) Z有见地~现在的状态是,I don't know what I want to be, and didn't be what others want to see.; A1 s: t/ k. i6 {' E
+ G1 [9 j+ M& t' S% @, M
! K9 N, i# J) h: U  W4 D9 B
yes, me too!we don't know what we want to be,but we must know what we should do---earn more money and learn skills.
1 x5 l7 W/ F5 w) {  F" P. b9 Y: k% @0 q
 楼主| 发表于 2013-8-14 11:33:36 | 显示全部楼层
webmastercn 发表于 2013-8-14 11:06 8 w, P# m4 a0 l4 q1 v4 c
yes, me too!we don't know what we want to be,but we must know what we should do---earn more money  ...
2 D5 D/ ^, \. ~3 b* H; f, m  HYou are right,but I think "earn more money and learn skills" Should be a part of life,not all of your life.5 C" G: R1 _1 b. K9 m7 h+ u5 \3 }
6 Y" y4 s5 _) `' U4 P' j
GMT+8, 2025-4-19 10:22
