查看: 1137|回复: 6
digitalocean可以的
发表于 2013-8-25 10:29:54 | 显示全部楼层 |阅读模式
Benchmark Run: Sun Aug 25 2013 09:56:37 - 10:24:55
1 CPU in system; running 1 parallel copy of tests
Dhrystone 2 using register variables       16271656.4 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     2539.3 MWIPS (10.0 s, 7 samples)
Execl Throughput                               4379.8 lps   (29.8 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        551315.0 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks          149493.9 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks       1125252.0 KBps  (30.0 s, 2 samples)
Pipe Throughput                              986411.2 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 191298.4 lps   (10.0 s, 7 samples)
Process Creation                              11483.7 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   4438.3 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                    580.3 lpm   (60.0 s, 2 samples)
System Call Overhead                         782494.6 lps   (10.0 s, 7 samples)
System Benchmarks Index Values               BASELINE       RESULT    INDEX
Dhrystone 2 using register variables         116700.0   16271656.4   1394.3
Double-Precision Whetstone                       55.0       2539.3    461.7
Execl Throughput                                 43.0       4379.8   1018.6
File Copy 1024 bufsize 2000 maxblocks          3960.0     551315.0   1392.2
File Copy 256 bufsize 500 maxblocks            1655.0     149493.9    903.3
File Copy 4096 bufsize 8000 maxblocks          5800.0    1125252.0   1940.1
Pipe Throughput                               12440.0     986411.2    792.9
Pipe-based Context Switching                   4000.0     191298.4    478.2
Process Creation                                126.0      11483.7    911.4
Shell Scripts (1 concurrent)                     42.4       4438.3   1046.8
Shell Scripts (8 concurrent)                      6.0        580.3    967.2
System Call Overhead                          15000.0     782494.6    521.7
System Benchmarks Index Score                                         902.5
发表于 2013-8-25 15:06:02 | 显示全部楼层
貌似很牛叉的样子
不错的选择
发表于 2013-8-25 22:26:26 | 显示全部楼层
听说linode能到2000多。。。
发表于 2013-8-26 00:06:38 | 显示全部楼层
都是英语啊,不是太明白了,
 楼主| 发表于 2013-8-26 07:02:35 来自手机 | 显示全部楼层
我这个是一个月5刀的,便宜很多
发表于 2013-9-21 14:11:12 | 显示全部楼层
我写过digitalocean的测评,http://www.zhujiceping.com/digitalocean-simple-testing/ 可以围观下!
发表于 2013-10-2 17:25:16 | 显示全部楼层
这个不错,正在用,价格也便宜,算是性价比高的
GMT+8, 2025-4-14 09:19
