查看: 2448|回复: 18
关于niche的文章外包
发表于 2013-9-2 15:38:16 | 显示全部楼层 |阅读模式
找好关键字以后,到文章外包之前,这个阶段,我看整个论坛讨论的都非常少,我随便说一下:
第一步:分析niche
我直接引用一段老外的话
its time to do some deep niche analysis and try to find out everything possible for our chosen niche.
合适的niche找到以后,可以开始对这个niche进行深度分析,并且需要是全方位的
This is a very important step in the whole process so lets dig in and get all the ins and outs of our niches.
这是一个非常重要的部分,我们需要反复研究的
Than I started going through the forums, what we are looking for is any questions people have, If there are any problems which needs solving in our niche, what people are talking about, If there are any hot debates going on, anything you find just note It down in a notepad.
通过搜索相关的论坛,来看看大家都怎么看待这个话题,是否有热门话题,还是有什么争议性的东西,包括疑惑和知识点,记录下来
Next go to yahoo answers and search for questions about your niche, see what people are asking frequently, anything you find just note it down.
同样的,可以去Q&A(比如yahoo answer)寻找,去观察用户问的最多的方面,记录下来
Next step go to amazon/ebay and look for best selling products or books in your niche
同样可以去亚马逊等电商平台,看看关于这个niche的产品都是如何的
Next go to Technorati.com or do a search on google your niche + blogs and search related blogs about your niche, go through some posts and see If you can find something interesting, make notes on how they have structered their blog, what are the topics people are making comments on. make notes of everything useful you find.
同样的,去搜索一些博客等资料,看看稍微专业的人士都怎么看待,看看里面有趣的或者有意义的文章,也可以看看他们的话题组织,还有评论等等
当然这些都要记录下来
Guys I want you to spend some time on this step, without this we wont be able to make a high quality site.
Remember we are making a site which is helpful and insightful for the visitor.
是的,我们需要花很多时间再这个步骤,我们需要做一个对读者有用的网站,当然必须要有点深度。
第二步:如何整理niche
这个下次再说,,,
第三步:根据整理的大纲,找合适的文章源
这个下下次再说,,,
asexy + 2 有見地
发表于 2013-9-2 15:46:30 | 显示全部楼层
你这篇文章说的问题,其实是很有难度的,所以国内讨论的少
1.niche进行深度分析,并且需要是全方位的
首先能深度分析的人,思维要相当敏捷,而且英语要非常好,对产品与销售深入了解并拥有经验才做的下来
2.通过搜索相关的论坛,来看看大家都怎么看待这个话题,是否有热门话题,还是有什么争议性的东西,包括疑惑和知识点,记录下来
同样是一个深度理解并概括产品的能力,对英语的要求非常高
其他的几个步骤,都是这样的
所以为什么国内做英文站始终停留在采集,粗浅模仿上
并且将长期存在
英语水平与理解能力是决定性的因素
非常小黑 + 1 送花花~~~
发表于 2013-9-2 15:53:26 | 显示全部楼层
楼主分析的不错的说。。
发表于 2013-9-2 15:54:09 | 显示全部楼层
英语很好的人,一般不会选择来做这行。。。
那也不一定,只是他们的选择面要广很多是真的  发表于 2013-9-2 16:43
发表于 2013-9-2 16:01:59 | 显示全部楼层
如果说做amazon niche站排名的话 外链这块应该是占了90%以上.内容etc顶多占了10%
这样说来,对新手是个好消息  发表于 2013-9-2 16:44
dealer + 1 認眞參與
 楼主| 发表于 2013-9-2 17:02:43 | 显示全部楼层
英语很好的,能干嘛?
4000一个月招英8的毕业生,3天能招20个。
你试试招一个真正懂IM的,30万年薪,能招到吗?
嗯,有道理,英语好的人可以去做同声传译。。  发表于 2013-9-3 13:01
 楼主| 发表于 2013-9-2 17:05:04 | 显示全部楼层
我觉得,这个思维不可取。
手工外链,说白了,还是黑帽。
去看看zz的操作手法,基本上还是靠 social+高质量的文章体系
除非你的目标就是一个月赚2000刀,那可以。
如果目标是一天2000刀,你绝对会否定你目前的思想。
 楼主| 发表于 2013-9-2 17:24:41 | 显示全部楼层
我觉得有一个取巧的办法。
比如找到一个niche,英语水平不够,或者英语找资料能力不够。
那就先看中文的资料,百度大家都没门槛吧。
这样研究1、2天,基本的思路也应该清楚了。
再根据整理的纲要,去反过来寻找类似的英文资料。
举例:
比如,想做IM,直接看bhw和wf,肯定很痛苦,不是?
那就先看tgl,花2天时间看通tgl上的东西,整理一份纲要
1、keywords research
    1.1、how to use ms to find a right keywords
    1.2、about competition and how to avoid
2、article rewrite
然后根据这份纲要,去找英文资料,那肯定很容易了。
实际上,也不容易,始终英语那方面缺了,做起来都不顺手  发表于 2013-9-2 18:45
发表于 2013-9-2 18:00:49 | 显示全部楼层
我也发过类似的翻译贴。现在调研niche和文章改写基本合在一起,搜素文章,看个大概,然后改写,边改写,边了解niche。
 楼主| 发表于 2013-9-2 18:16:13 | 显示全部楼层
嘻哈 发表于 2013-9-2 18:00
我也发过类似的翻译贴。现在调研niche和文章改写基本合在一起,搜素文章,看个大概,然后改写,边改写,边 ...
自己写???
不外包吗???
高手啊
发表于 2013-9-2 18:28:31 | 显示全部楼层
改写产品的review文章,找一个产品的多篇review文章,结合amazon的页面,拼凑,改写。
发表于 2013-12-11 16:28:21 | 显示全部楼层
非常小黑 发表于 2013-9-2 17:02
英语很好的,能干嘛?
IM是什么??求指教。。
Internet marketing……  发表于 2014-8-13 23:09
发表于 2014-1-10 14:44:07 | 显示全部楼层
that moral education is the infrastructure of higher learning. (许多人认为道德教育是高等知识的基础) (如果用 foundation 或 basis 代替 infrastructure 就更明白)
Three hundred acres of land is the parameter of our university,s expansion (growth). (三百英亩的土地是本大学发展的限度) (如果用limit代替parameter,会更简单易懂。)
This news has been disseminated all over the U.S. (这消息已散布到全美各地) (如果用spread取代disseminated,不更简单?) (动词时态是:
发表于 2014-8-13 22:07:04 | 显示全部楼层
每一句话都可以学着用啊,谢谢楼主分享
发表于 2014-8-13 22:15:24 | 显示全部楼层
黑神厉害~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
发表于 2014-8-13 23:06:08 | 显示全部楼层
非常小黑 发表于 2013-9-2 17:24
我觉得有一个取巧的办法。
那就先看中文的 ...
刚开始可以先通过中文的了解行业现状和专业术语,但是后期必须彻底抛开中文思维,这样进步才会快,个人感觉
发表于 2014-8-13 23:08:56 | 显示全部楼层
非常小黑 发表于 2013-9-2 18:16
自己写???
不外包吗???
高手啊
我也试过,搜5篇左右的文章来进行改写,方法是可以的,但是很花时间,600字几乎要花掉我一个下午。
同样由于英语水平不够,一些自己新增的润色的句子总感觉很别扭。
发表于 2014-8-13 23:10:10 | 显示全部楼层
xz21st 发表于 2014-1-10 14:44
that moral education is the infrastructure of higher learning. (许多人认为道德教育是高等知识的基础)  ...
这种简单的改个单词的伪原创对google来说意义不大,还是要在理解的基础上去加油添醋。
发表于 2014-8-14 00:03:54 | 显示全部楼层
之前论坛有个兄弟发了个连接http://topsy.com/,非常适合对niche深入挖掘。他融合了各大主流社交网站对关键词的热门谈论内容。之前我关注一个练数成金的论坛,里面有个关于分析社交网络对谷歌,苹果的讨论,来判断它们股价的趋势的判断。有空我转发一下。
GMT+8, 2025-4-12 13:15
