查看: 5533|回复: 56
Review写作速成——教你快速写出高质量高转化率的Review文章
发表于 2013-9-4 01:48:54 | 显示全部楼层 |阅读模式
在论坛逛了挺长时间了,没怎么发过经验帖,其它自己也没多少经验可写。昨天下载了Rapid_Fire_Writing和quick_converting_content_system,再结合近月来自己写文章的经验,在这里总结一下。
注:文章大部分是读了英文资料后翻译而来,高手请无视。
一、标题:最简单的标题是 Product Name + Review(s),新颖的标题可以轻易抓住读者的眼球,使得他不得不读下去。
1.    使用副标题: xxx review – Is it the best xxx ?
a)     Porter-Cable C2002-WK Oil-FreeUMC Pancake Comparessor – How Powerful isit?
b)      Porter-Cable C2002-WK Oil-Free UMC Pancake Comparessor – Durable AirCompressor
c)      Porter-Cable C2002-WK Oil-Free UMC Pancake Comparessor – Free UMCPancake Compressor?
2.    常用的标题格式
a)      发起争论:XXXX review - Is this XXX Really worthyour money?
b)      在读者脑海中建立产品形象:Crystal Clear HD Picture – Does the Sharp Aquos Quattron LC-40LE830U Deliver?
c)      直接进入主题: xxxx review
d)      开始一个对话:Thinking about buying XXX ?
e)      引发读者好奇心:What You Need to Know About the SharpAquos Quattron LC – 40LE830 LCD TV
f)       发出命令:Don’t Buy the Sharp Aquos Quattron 40LE830 LCD TVUntil You Read This Review
g)      一点诱饵:Why the Sharp Aquos Quattron 40LE830LCD TV Drives Me Crazy !
二、内容:
1.    禁忌
a)      不要看低读者的智商:我们在写Review(类似软文), 而不是广告,文章要够软才行。而不是直白的夸耀自己的Niche产品,而贬低其它产品。
反例:
“Obviously, theXYZ product is far superior to other widgets. If
you’ve ever useda brand other than XYZ, you know that these
widgets are ofextremely low quality.”
修改后:
“You’ve probablyheard quite a few people saying that the XYZ
Widget is one ofthe best widgets that money can buy. And, like
me, you’veprobably used a widget or two in the past. After
reading quite afew XYZ widget reviews, I have to say that I am
pretty darnedimpressed with XYZ widget, and, quite frankly, I
agree that thesejust may be the best widgets on the market today.”
想象你在像亲朋好友推荐你觉得很好的一款产品,例如对方是一名生活很节俭的中年妇女,你该推荐本产品,她才会动心呢?
⑴产品的好只通过你的举例或详尽描述展现出来才更有说服力。⑵采用对话的方式,像在跟读者(想象成自己的一位好朋友)对话,你的话句中处处体现着为她着想的感觉,而不仅是在推销某款产品(像推销员)。
b)      不要只列产品特性而不加诠释:
反例:
. 4 HP Motor
      . Comes with a blade brake and wrap-aroundhandle
      . 18 inch guide bar
      . 1 year warranty
修改后:
      . Built with a powerful 4 horsepower motorso you can rip
through thetoughest lumber with ease.
      . Stay safe while cutting with theintegrated blade brake and
sturdywrap-around handle.
      . The 18 inch steel guide bar allows youto cut with precision,so you have total control over every cut.
      . Backed by a full 1 year warranty toprotect your purchase.
把用户的需要分解后,掺杂到产品特性中去,这样会让读者看到产品实实在在的优势。
c)      没有告诉读者该做什么:你为什么写这篇Review/post 呢,无非是想让读者通过aff链接到Amazon购买产品,或者通过分享按钮分享文章到其它网站,或者留言讨论,或者点击Like/评分。那么你应该在文章结尾处写出来,提醒读者在读完本文章后该去做什么。
2.    Review 速成法:下面的内容跟上文来自不同的资料,没有任何联系,上文旨在提高文章转化率,下文旨在在最短的时间内写出Review(作者是写给英文写手看的)。
a)      动笔前的准备工作(本步骤需设定时间限制,如10min左右)
                 i.     查看产品性能,特点
                 ii.    制造商/Amazon对产品的描述
                 iii.   用户Review (重点步骤,需要记下可以使用的点)
b)      按照一定的格式填充内容(时间最好限制在20分钟内)
                 i.     开场白(约90words): 使用对话的语气,像对好友亲人讲解你所了解的产品。
                 ii.    过渡段(约150words): 重点突出产品的1-3个特性,每个特性为一段,使用子标题。
                 iii.    优点和特性(约100words):结合features伪原创
                 iv.    总结(约140words):结合Amazon产品页中用户的评论,最后简述产品的优点和缺点。
这样,30分钟内应该就可以完成一篇资质普通的500词Review文章,原文作者说只需要15Min,手熟后可以5分钟一篇review, 这个说法太不实际,我觉得在30分钟内应该可以的。当然具体还要看英文水平。
例文
DeLonghi EC155 Espresso MakerReview
If you're anything like me, andlove a good cup of espresso to get your day started, you know how important itis to have a high quality espresso maker at home. The DeLonghi EC155 EspressoMaker is an espresso maker that's been in high-demand for the past few years.And since I'm always on the lookout for a way to enjoy authentic, Italian-styleespresso, I decided to do some research on this popular model, so I could shareit with you here in this DeLonghi EC155 Espresso Maker review.
Pure Pumping Power(使用子标题使文章结构明显,并突出产品特性)
Making authentic, deliciousespresso at home can be difficult with stove-top espresso pots, as they simplydon't use the same approach that an authentic espresso maker, like the DeLonghiEC155 Espresso Maker uses. You see, real Italian bistros and coffee shops usepump-driven espresso machines. Fortunately, the DeLonghi EC155 Espresso Makeruses 15 bar pumping action to make every cup brewed as tasty and piping hot aspossible.
Easy to Clean
And if you're searching around forthe best espresso maker, you probably don't want one that is too difficult ortime consuming to clean up. The DeLonghi EC155 Espresso Maker is made to allow simple,quick clean ups. With its removable drip tray, you never have to worry aboutbig messes in the kitchen. And since the DeLonghi EC155 Espresso Maker hasdishwasher safe parts, you can have this powerful espresso maker cleaned up andready to brew in no time at all.
Features & Specifications
• Built with a 15 bar pumpsystem to give you authentic espresso
• Integrated stainless steelboiler that's built to last for years to come
• Features 2 separatethermostats for individual control over water and steam pressure options
• This espresso maker isself-priming, so you don't have to fuss with a manual priming system
• Uses E.S.E. Pods and groundespresso, so have more choices for your espresso
• Built with a swivel jetfrother to add delicious frothed milk to your drinks
• 35 ounce water tank is simpleto remove for fill ups and clean ups
• Dimensions:7-1/2 by 9-1/2 by11-1/8 inches
• Backed by a powerful 1-yearwarranty
The Customer Reviews &Scores
No DeLonghi EC155 Espresso Maker review would be complete without discussing the real life customerreviews for this model. While doing research for this espresso maker review, Ifound over 600 helpful customer reviews. All told, this espresso maker hasracked up an impressive 4.1 out of 5 star rating. That means that the vastmajority of people have given this espresso maker the highest marks possible. And while there were some minorcomplaints about the frother wand being a bit too low for some peoples' liking,the overall consensus is that the DeLonghi EC155 Espresso Maker is one of thebest espresso makers in this price class. If you've been looking for anespresso maker to start your mornings off on the right foot, I highly recommendthe DeLonghi EC155 Espresso Maker
三. 个人看法
刚开始写文章时受ZZ大神每天30篇的速度影响,再加上自认为英文水平还不错,认为只要够努力,每天写30篇没问题。但在实际中, 自己的步骤如下:
1. 选产品(约5min)
2. 使用Adwords选中适合的关键词2-4个(5min)
3. GG搜索与产品相关的资料,一般是三篇Review, 有时还看论坛的讨论都读一遍,作笔记(>30min)
4. 开始写,结合找到的资料,写出的Review文章可以轻松通过Copyscope,并在Copyscope Compare中与任一篇对比 match rate都低于10%。(40min)
5. 寻找3-5张图片,文章排版发布。
但这样一篇Review无论如何也要1.5小时以上。一天也写不出几篇来。
现在的想法是,质量要求较高的文章,使用这种方法写,每天写2-3篇就可以。对于普通的文章/review, 就使用上面的 Review 速成法, 相信熟练后可以在0.5h内完成。两者结合使用,在速度和质量上可以达到折中。
参与人数 17e币 +36 收起 理由
sure15 + 1 有見地
webmastercn + 1 不错的总结
backtoy + 1 鼓勵
华隐 + 3
tkmy + 2
月光飞燕 + 5
热过火 + 1 有見地
zgytljswzk + 2 楼主,你知道的太多了
wawylysys + 2 認眞參與
ADbb + 3 不错的经验总结,给力
Terry + 1
bbhit + 2 谢谢分享!
yangjianfeng + 4 送花花~~~
cgsky + 1 有見地
idea2money + 1
adver + 3 谢谢分享!
hudba + 3 楼主正以120码的速度奔向通往美刀的大路.
 楼主| 发表于 2013-9-4 02:28:41 | 显示全部楼层
另,在工作之中会经常地遇到大大小小问题,这些问题汇集成了一道道很难过的坎,我的习惯是遇到这些坎,总是想着做些别的来转移注意力(如休息),这样就往往走不过去。 但现在每每遇到坎就想起“其间解决了各种难题,你们无法想象的,我都化解了,很满意。” 那句话,强者自强,弱者自弱,强弱不是天生的,而是后天个人自己的选择。在坎面前我在想,如果大佬仍会遇到这样那样的坎(另人无法想象的),刚起步的我们遇到坎就更正常了。或许那条通向神坛的道路正是前进边迈过一道道坎走来的。所以如果要成为强者,可以因遇到的坎减缓前进的步伐,但决不能在坎面前停滞。
参与人数 5e币 +7 收起 理由
月光飞燕 + 3
热过火 + 1 有見地
pitch + 1 有見地
专心 + 1
yangjianfeng + 1 有見地
发表于 2013-9-4 02:52:28 | 显示全部楼层
流程好像也不复杂:
信息的理解
信息的筛选
信息的重写rewrite
发表于 2013-9-4 05:56:19 | 显示全部楼层
整理得很好,学习了……
发表于 2013-9-4 08:28:05 | 显示全部楼层
我也刚看完rapid fire writing
他这个模板确实也比较高效
但是我想会不会很多人都是用的这种形式
导致用户会对这种形式的review感到疲劳?
发表于 2013-9-4 08:34:41 | 显示全部楼层
很好的不错,加油
发表于 2013-9-4 08:38:26 | 显示全部楼层
其实很有道理,我刚开始弄,结果主机就出了问题,主机商给了我两个账号,前者用不了,后者可以用,但是他又发信息来说我的前者没付款,我勒个去,被他弄晕了,后来又发现后者送的渔民无法进入CPANEL,于是又写了封信去沟通,今天又催我付款,晕了,现正沟通中,希望第一步不要那么麻烦,快点解决,不然都打击我信心了
发表于 2013-9-4 08:53:12 | 显示全部楼层
很详细的模板。好。
发表于 2013-9-4 09:12:24 | 显示全部楼层
孰能生巧,遇到困难需要自己想办法解决。
发表于 2013-9-4 09:24:07 | 显示全部楼层
楼主很是用心了,谢谢分享这么好的经验总结
 楼主| 发表于 2013-9-4 09:46:03 | 显示全部楼层
yangjianfeng 发表于 2013-9-4 08:38
其实很有道理,我刚开始弄,结果主机就出了问题,主机商给了我两个账号,前者用不了,后者可以用,但是他 ...
是的,我也是遇到这些问题,我用自己的VPS搭建的SSH,经常被谷歌屏蔽无法搜索,MarketSamurai 试用过期重装无法使用,Ahref一个注册账户免费只能查在次,新版Adwords keyword plan不熟悉, Dreamhost 新添加域名却一直不给换IP,等等,虽都是小问题,积累起来真让人头疼。
参与人数 2e币 +4 收起 理由
yangjianfeng + 2 都有心!
001 + 2 都是这么过来的.
发表于 2013-9-4 10:06:05 | 显示全部楼层
总结得很不错,赞一个
发表于 2013-9-4 10:06:45 | 显示全部楼层
似乎不错,mark一下
发表于 2013-9-4 10:11:13 | 显示全部楼层
总结的很好额,分分加上,5分钟一篇纯卖萌的,根本没有计算整理资料的时间。
zz的30篇指的好像是文章信息站的改写,而不是全原创
发表于 2013-9-4 10:15:59 | 显示全部楼层
楼主的总结,节省了我不少时间,待会实践一遍好了。
发表于 2013-9-4 11:28:42 | 显示全部楼层
很好的总结,步骤够详细的。
发表于 2013-9-4 11:33:13 | 显示全部楼层
什么方法都好,关键在于锻炼,学了不练,白学
发表于 2013-9-4 11:37:06 | 显示全部楼层
对于英文不好的来说 还是很难写出..
发表于 2013-9-4 11:48:59 | 显示全部楼层
最喜欢看别人的总结,然后自己再总结。
发表于 2013-9-4 11:53:41 | 显示全部楼层
不错  这两天就要开始写review了。。。
GMT+8, 2025-4-25 08:15
