查看: 998|回复: 12
求分析,求指导ixwebhosting主机
发表于 2013-9-21 17:06:44 | 显示全部楼层 |阅读模式
一个ixwebhosting的主机账户收到一份邮件.是不是让我同意个什么,如果不同意就就让我换托管商么,求懂得人解释一下.内容如下,非常感谢.
As part of IX Web Hosting's ongoing compliance initiatives, we have identified recent changes in the Health Insurance Portability and Accountability Act ("HIPAA") that may impact some of IX's customers. Specifically, these changes require Covered Entities and all of their Business Associates who create, receive, maintain transmit or have access to protected health information (or the possibility exists that the protected health information in the business associate's custody or control could be compromised) to independently comply with HIPAA.
To help identify those customers who may be impacted, IX is asking its customers to notify IX if they are considered a Covered Entity or Business Associate under HIPAA and store or transmit electronic protected health information using IX's services. IX will assume that the recent changes in HIPAA do not impact IX customers who do not identify themselves as a Covered Entity or Business Associate. IX has also updated its Terms of Service with customers to prohibit the use of protected healthcare information on websites that IX hosts.
If you answer "yes" to both of the following questions, please contact [email protected]no later than 09/23/2013.
  • Is your business a Covered Entity or a Business Associate as defined by the Health Insurance Portability and Accountability Act of 1996 or HIPAA (45 CFR 160.103)?
  • If so, are you maintaining or transmitting Protected Health Information or PHI (defined in 45 CFR 160.103) using any of the IX services?
If you did not answer "yes" to both of the above questions, there is no need for further action
Please see below for some frequently asked questions.
We appreciate your cooperation and look forward to continuing to serve you.
If I answer "yes" to both questions will my service be impacted or change as a result of the new regulations? What if I answer "no"?
If you answer "yes" to both questions your services will change. You must transfer to another hosting provider. Upon request, we can provide you with the name of a provider who is HIPAA compliant and operating in a HIPAA compliant data center. If you answer "no", there will be no changes to your services at this time.
If I answer "yes" to both questions what will IX do with the information that I provide?
IX will use the information to recommend you transfer your account to a provider who can supply HIPAA compliant services.
Will I be contacted by an IX representative whenever new regulations apply to my business?
Not necessarily. We may contact you if the regulations apply to and affect IX's provision of services to you.
Thank You,
IX Web Hosting
发表于 2013-9-21 17:41:29 | 显示全部楼层
楼主是做健康站的吧,具体我也看不大懂,楼下解答.
是有一个健康站  发表于 2013-9-21 18:49
发表于 2013-9-21 18:21:40 | 显示全部楼层
一个破主机,要求挺多。
要求是蛮多的  发表于 2013-9-21 19:36
发表于 2013-9-21 18:32:25 | 显示全部楼层
关键是这句话,IX has also updated its Terms of Service with customers to prohibit the use of protected healthcare information on websites that IX hosts.
IX不允许你在他们主机上使用受保护的医疗计划信息。如果有参与这种活动的话(回答yes的话),请乖乖地向IX缴械投降。
参与人数 2e币 +5 收起 理由
yangjianfeng + 2 有見地
001 + 3 谢谢解答
发表于 2013-9-21 18:42:38 | 显示全部楼层
发表于 2013-9-21 19:09:36 | 显示全部楼层
还没见过有这种要求的。。。。。。。。。。
反正不到两月到期了,拾掇拾掇,几个有用的高出来,没用的随他便吧.  发表于 2013-9-21 19:39
发表于 2013-9-21 19:57:33 | 显示全部楼层
珍爱生命 远离IX,用他们的主机跟看中国足球一个心情 Good luck
唉,说多了都是泪啊,.转移空间去了.  发表于 2013-9-21 20:16
发表于 2013-9-21 19:58:36 | 显示全部楼层
楼主为什么要用这个破公司呢?
 楼主| 发表于 2013-9-21 20:13:28 | 显示全部楼层
小兵过河 发表于 2013-9-21 19:58
楼主为什么要用这个破公司呢?
去年买的时候是200左右一年.15IP独立,1个共享.还送3个域名的.多实惠啊,呵呵,
发表于 2013-9-21 21:34:15 | 显示全部楼层
做站群可以用用 主站还是不要放
 楼主| 发表于 2013-9-21 21:58:05 | 显示全部楼层
minlab 发表于 2013-9-21 21:34
做站群可以用用 主站还是不要放
一个cb健康类的产品,后来那个类型的产品没有一个了.网站没有再管理过
发表于 2013-9-22 07:59:17 | 显示全部楼层
口碑不咋地的一主机服务提供商
发表于 2013-9-26 17:14:03 | 显示全部楼层
IX对国内体验很差,话说对本土美国应该好点吧?
GMT+8, 2025-4-13 01:07
