查看: 1199|回复: 2
prometeus-达拉斯数据中心VPS简单测评,适合E文站
发表于 2013-9-22 23:12:05 | 显示全部楼层 |阅读模式
找个稳定还便宜的VPS对于喜欢搞网挣的人应该来说是件好事儿,这里推荐的是prometeus新开的达拉斯数据中心的openvz:384M内存,384M vswap,12g ssd,2T流量,年付21欧。
prometeus这款达拉斯的基于openvz的VPS我拿到后的一点数据和大家分享:服务器托在inceronetwork,G口,在全世界都尼玛可以就国内悲剧,联通走nlayer,从chinaz来看不管电信还是联通都不是那么理想。特色在于1.7G这个I/O估计有些商家蛋都碎了,SSD果然给力。E3 1270的U给了1核没有限频E3-1270 v3 @ 3.50GHz,384M的内存+384的vswap(2代),12G SSD,2T流量,对于外贸站貌似可以,国内要用的话可以加个反代才行或者CDN才行!
下面是广州联通追踪:
|                                      WinMTR statistics                                   |
|                       Host              -   %  | Sent | Recv | Best | Avrg | Wrst | Last |
|           Destination host unreachable. -   15 |   85 |   73 |    0 |    0 |    1 |    0 |
|           Destination host unreachable. -   14 |   84 |   73 |   18 |   26 |   93 |   22 |
|                          120.80.175.193 -   14 |   84 |   73 |   18 |   22 |   34 |   22 |
|                             120.84.0.49 -   15 |   80 |   68 |    0 |   23 |   38 |   22 |
|                           219.158.99.93 -   13 |   83 |   73 |   44 |   48 |   55 |   46 |
|                           219.158.4.210 -   20 |   72 |   58 |    0 |  109 |  124 |  101 |
|                           219.158.97.74 -   15 |   80 |   68 |   97 |  108 |  121 |  100 |
|           Destination host unreachable. -   22 |   74 |   58 |    0 |  307 |  316 |  300 |
|         xe-6-0-3.ar1.lax2.us.nlayer.net -   43 |   47 |   27 |  309 |  323 |  390 |  317 |
|          ae1-80g.cr1.lax1.us.nlayer.net -   23 |   68 |   53 |    0 |  294 |  305 |  288 |
|         xe-2-0-1.cr1.dfw1.us.nlayer.net -   14 |   79 |   68 |  341 |  356 |  440 |  342 |
|          ae1-50g.ar1.dfw1.us.nlayer.net -   15 |   80 |   68 |  297 |  361 |  452 |  357 |
|           Destination host unreachable. -   17 |   79 |   66 |    0 |  328 |  340 |  332 |
|      as54540.ae5.ar2.dfw1.us.nlayer.net -   18 |   76 |   63 |    0 |  367 |  390 |  364 |
|      bc2-side-from-r1.inceronetwork.com -   18 |   76 |   63 |    0 |  346 |  359 |  345 |
|       192-211-58-98-customer-incero.com -   18 |   76 |   63 |    0 |  313 |  323 |  313 |
|      192-211-58-xxx-customer-incero.com -   18 |   76 |   63 |  306 |  317 |  389 |  309 |
|________________________________________________|______|______|______|______|______|______|
   WinMTR v0.92 GPL V2 by Appnor MSP - Fully Managed Hosting & Cloud Provider
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
[email protected]:~#  cat /proc/cpuinfo
processor       : 0
vendor_id       : GenuineIntel
cpu family      : 6
model           : 60
model name      : Intel(R) Xeon(R) CPU E3-1270 v3 @ 3.50GHz
stepping        : 3
cpu MHz         : 3499.882
cache size      : 8192 KB
physical id     : 0
siblings        : 8
core id         : 0
cpu cores       : 4
apicid          : 0
initial apicid  : 0
fpu             : yes
fpu_exception   : yes
cpuid level     : 13
wp              : yes
flags           : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts rep_good xtopology nonstop_tsc aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm ida arat epb xsaveopt pln pts dts tpr_shadow vnmi flexpriority ept vpid fsgsbase bmi1 hle avx2 smep bmi2 erms invpcid rtm
bogomips        : 6999.76
clflush size    : 64
cache_alignment : 64
address sizes   : 39 bits physical, 48 bits virtual
power management:
[email protected]:~# cat /proc/meminfo
MemTotal:         393216 kB
MemFree:          380008 kB
Cached:             9640 kB
Active:            10216 kB
Inactive:           1328 kB
Active(anon):       1380 kB
Inactive(anon):      524 kB
Active(file):       8836 kB
Inactive(file):      804 kB
Unevictable:           0 kB
Mlocked:               0 kB
SwapTotal:        393216 kB
SwapFree:         393216 kB
Dirty:                 0 kB
Writeback:             0 kB
AnonPages:          1904 kB
Shmem:              2584 kB
Slab:               1648 kB
SReclaimable:        768 kB
SUnreclaim:          880 kB
[email protected]:~# df -lh
Filesystem      Size  Used Avail Use% Mounted on
/dev/simfs       12G  495M   12G   5% /
tmpfs            39M   24K   39M   1% /run
tmpfs           5.0M     0  5.0M   0% /run/lock
tmpfs           154M     0  154M   0% /run/shm
[email protected]:~# wget http://cachefly.cachefly.net/100mb.test
--2013-09-22 14:06:53--  http://cachefly.cachefly.net/100mb.test
Resolving cachefly.cachefly.net (cachefly.cachefly.net)... 205.234.175.175
Connecting to cachefly.cachefly.net (cachefly.cachefly.net)|205.234.175.175|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 104857600 (100M) [application/octet-stream]
Saving to: `100mb.test'
100%[======================================>] 104,857,600 87.7M/s   in 1.1s
2013-09-22 14:06:54 (87.7 MB/s) - `100mb.test' saved [104857600/104857600]
[email protected]:~# dd if=/dev/zero of=test bs=64k count=16k oflag=dsync
16384+0 records in
16384+0 records out
1073741824 bytes (1.1 GB) copied, 3.05453 s, 352 MB/s
[email protected]:~# wget freevps.us/downloads/bench.sh -O - -o /dev/null|bash
CPU model :  Intel(R) Xeon(R) CPU E3-1270 v3 @ 3.50GHz
Number of cores : 1
CPU frequency :  3499.882 MHz
Total amount of ram : 384 MB
Total amount of swap : 384 MB
System uptime :   8 min,
Download speed from CacheFly: 110MB/s
Download speed from Coloat, Atlanta GA: 70.6MB/s
Download speed from Softlayer, Dallas, TX: 111MB/s
Download speed from Linode, Tokyo, JP: 15.9MB/s
Download speed from i3d.net, NL: 15.1MB/s
Download speed from Leaseweb, Haarlem, NL: 15.5MB/s
Download speed from Softlayer, Singapore: 15.8MB/s
Download speed from Softlayer, Seattle, WA: 67.0MB/s
Download speed from Softlayer, San Jose, CA: 70.6MB/s
Download speed from Softlayer, Washington, DC: 68.3MB/s
I/O speed :  1.7 GB/s
原文:http://www.zhujiceping.com/prometeus-dallas-vps-review/
发表于 2013-9-23 06:37:26 | 显示全部楼层
看广告不如看疗效
楼主敢透露一些典型的用户吗
 楼主| 发表于 2013-9-23 13:14:50 | 显示全部楼层
th3grouplet 发表于 2013-9-23 06:37
看广告不如看疗效
楼主敢透露一些典型的用户吗
我只是自己买了一款把一些VPS的参数细节透漏出来,我到哪里给你去找典型的用户!从我用他们家的KVM来看280天的在线不宕机还是能说明一点儿情况吧!
GMT+8, 2025-4-12 21:57
