查看: 1334|回复: 9
推荐一款实惠的独立服务器,已自用三个月
发表于 2013-10-17 09:29:31 | 显示全部楼层 |阅读模式
PhoenixNAP SecuredServers
www.securedservers.com
用的是78$/月的套餐。蛮稳定的,免费的Plesk面板也好用,客服也OK。
RAM (In GB)
        8 GB ECC DDR3 (Included)                                        $0
        16 GB ECC DDR3                                        $20
        32 GB ECC DDR3                                        $50
RAID OPTIONS
        No Raid                                        $0
        Software RAID 1 - (Requires 2 identical SATA HDDs)                                        $0
PRIMARY HARD DRIVE OPTIONS
        250 GB Enterprise Grade SATA II (Included)                                        $0
        500 GB Enterprise Grade SATA II                                        $5
        1 TB Enterprise Grade SATA II                                        $15
        2 TB Enterprise Grade SATA II                                        $25
        3 TB Enterprise Grade SATA II                                        $45
        64 GB Samsung SSD                                        $20
        120 GB Samsung SSD                                         $25
        240 GB Samsung SSD                                         $50
        480 GB Samsung SSD                                         $90
HARD DRIVE 2 OPTIONS
        No Additional Drives                                        $0
        250 GB Enterprise Grade SATA II                                        $0
        3 TB Enterprise Grade SATA II                                        $60
        120 GB Samsung SSD                                        $40
        240 GB Samsung SSD                                         $70
        480 GB Samsung SSD                                         $100
BANDWIDTH UPGRADE OPTIONS ($0.10/GB for Overages)
        3200 GB Transfer (10 Mbps Uplink) (Included)                                        $0
        3200 GB Transfer (100 Mbps Uplink)                                         $3
        3200 GB Transfer (1 Gbps Uplink)                                         $5
        5 TB Transfer (100 Mbps Uplink)                                        $8
        5 TB Transfer (1 Gbps Uplink)                                        $10
        10 TB Transfer (100 Mbps Uplink)                                         $15
        10 TB Transfer (1 Gbps Uplink)                                         $20
        20 TB Transfer (100 Mbps Uplink)                                        $25
        20 TB Transfer (1 Gbps Uplink)                                        $30
        30 TB Transfer (100 Mbps Uplink)                                        $35
        30 TB Transfer (1 Gbps Uplink)                                        $40
        40 TB Transfer (100 Mbps Uplink)                                        $45
        40 TB Transfer (1 Gbps Uplink)                                        $50
        50 TB Transfer (100 Mbps Uplink)                                        $55
        50 TB Transfer (1 Gbps Uplink)                                        $60
        100 TB Transfer (1 Gbps Uplink)                                        $100
PRIMARY IP ALLOCATION
        /29 IP allocation (5 usable IPs) (Included)                                        $0
                                                Additional IP Addresses - Our servers are provisioned and released by default with a /29 VLAN (5 usable IP's). If you require additional IP space please select from the options below. Our support staff will provide you with an IP Justification Form in order to receive the additional IP allocation.
ADDITIONAL IP ALLOCATION
        No Additional IPs                                        $0
        /29 VLAN Allocation (5 usable IPs)                                        $5
        /28 VLAN Allocation (13 usable IPs)                                        $13
        /27 VLAN Allocation (29 usable IPs)                                        $26
OPERATING SYSTEM
        CentOS 64 Bit (Latest Stable) (Included)                                        $0
        FreeBSD 64 Bit (Latest Stable)                                        $0
        Ubuntu LTS 64 bit (Latest Stable)                                        $0
        Debian 64 bit (Latest Stable)                                        $0
        VMware ESXi                                        $0
        Windows Server 2008 Web 64 bit (R2)                                        $10
        Windows Server 2008 Std 64 bit (R2)                                        $15
        Windows Server 2008 Ent 64 bit (R2)                                         $50
        Windows Server 2008 DC 64 bit (R2)                                         $65
        Custom (Client Installed via IPKVM) - Please provide ISO link in "Special Instructions" box below                                        $0
CONTROL PANELS
        No Control Panel                                        $0
        Webmin (CentOS/Ubuntu/Debian)                                        $0
        Parallels Plesk - (10 Domain)                                        $0
        Parallels Plesk - (100 Domain)                                        $24
        Parallels Plesk - (Unlimited Domain)                                        $42
        cPanel/WHM and Softaculous                                        $20
        cPanel/WHM and Fantastico de Luxe                                        $24
        Webuzo                                        $2
CONTROL PANEL ADD-ONS
        No Add-on Pack                                        $0
        Plesk Power Pack                                        $15
SOFTWARE OPTIONS
        No Software                                        $0
        MySQL                                        $0
        Microsoft SQL Express                                        $0
        Microsoft SQL Standard                                         $240
                                                Looking for Microsoft options not listed? Contact our sales team.
参与人数 2e币 +2 收起 理由
z11zhang + 1 送花花~~~
adrian + 1
发表于 2013-10-17 11:49:53 | 显示全部楼层
目前只能用得起 vps
vps好像比独服简单那一点吧
发表于 2013-10-17 11:53:34 | 显示全部楼层
记一下,目前还用不上独立服务器
发表于 2013-10-17 12:14:48 | 显示全部楼层
麻麻嘚,独服从ovh起步吧。
发表于 2013-10-19 12:40:11 | 显示全部楼层
楼主,你的网站是个大站吧?
还是有许多个网站?
好像服务器对大站比较合适。
 楼主| 发表于 2013-10-21 11:16:52 | 显示全部楼层
这个服务器有五个独立IP,可以做五个大点的主站
发表于 2013-10-21 12:15:24 来自手机 | 显示全部楼层
有钱人,用独服,我只能用的起虚拟主机。
发表于 2013-10-31 20:21:05 | 显示全部楼层
真是有钱人啊 土豪 土豪
发表于 2013-11-6 17:27:48 | 显示全部楼层
貌似不错,买台用用
发表于 2013-11-6 20:58:15 | 显示全部楼层
都是土豪啊。。不过这机器貌似挺便宜的啊。。就是不知道性能咋样
GMT+8, 2025-4-17 22:21
