查看: 796|回复: 11
今天收到godaddy关于域名的信,是什么意思呢
发表于 2013-11-9 21:32:24 | 显示全部楼层 |阅读模式
Please update your contact information
Dear hgood,
It's that time of year. Because you are the ADMINISTRATIVE CONTACT for the following domain names registered at GoDaddy as of 11/9/2013, ICANN, the Internet Corporation for Assigned Names and Numbers (and/or the associated ccTLD authority), requires that we ask you to review your contact data and make any changes necessary.
          GOODXXXXXX.COM
                To review/update your contact information, click here.
If you find that your domain contact data is current and accurate, there's no need to take action. If, however, your domain contact information is inaccurate, you must correct it. (Under ICANN and ccTLD WHOIS rules and the terms of your registration agreement, PROVIDING FALSE CONTACT INFORMATION CAN BE GROUNDS FOR DOMAIN NAME CANCELLATION.) To review the ICANN policy, visit: http://www.icann.org/en/whois/wdrp-registrant-faq.htm
我注册域名时的电话和联系地址都是随便填的,是不是被发现我的信息不对啊,需要修改成正确的联系信息吗?谢谢了
发表于 2013-11-9 21:42:20 | 显示全部楼层
我注册Godaddy也是随便写,还没有收到类似的信
发表于 2013-11-9 21:56:15 | 显示全部楼层
提醒而已 可以不用管的
发表于 2013-11-9 22:23:59 | 显示全部楼层
让你更新帐户信息。
 楼主| 发表于 2013-11-9 22:26:51 | 显示全部楼层
谢谢,那我就不理他了
发表于 2013-11-9 22:31:27 | 显示全部楼层
不用理他就对了,正常的通知邮件。
发表于 2013-11-9 23:27:20 | 显示全部楼层
貌似都会发这个吧,应该木事的
发表于 2013-11-10 04:15:17 | 显示全部楼层
没收到过这样的邮件,在godaddy也有几个域名
发表于 2013-11-10 07:43:29 | 显示全部楼层
不用管它吧  哎   老外就是烦
发表于 2013-11-10 18:59:38 | 显示全部楼层
经常能收到,从来不理他
发表于 2013-11-10 20:32:35 | 显示全部楼层
只要不是用的国外优惠码一切都OK拉哈哈
发表于 2013-11-10 22:09:44 | 显示全部楼层
要你修改联系方式~~~~~~~
GMT+8, 2025-4-15 13:29
