查看: 1024|回复: 1
询问一个关于无法修改分类名的问题
发表于 2013-12-19 10:07:51 | 显示全部楼层 |阅读模式
刚安装wp,修改后台分类是有问题了
Edit Category
Name
The name is how it appears on your site.
Slug
The “slug” is the URL-friendly version of the name. It is usually all lowercase and contains only letters, numbers, and hyphens.
Parent
Categories, unlike tags, can have a hierarchy. You might have a Jazz category, and under that have children categories for Bebop and Big Band. Totally optional.
Description
                        The description is not prominent by default; however, some themes may show it.
slug 一行 这里怎么修改都没反应,留空的话 就变成分类名后面加一个随机数字,修改了保存不了
是不是我的目录权限不对?
发表于 2013-12-21 13:33:11 | 显示全部楼层
这数字不是随机的.
这数字是代表第n个相同term(tags, category, links, custom tax)名.
要是理解了, 你就知道你问题的原因
GMT+8, 2025-4-4 15:09
