查看: 2788|回复: 25
原创5篇amazon产品review作为练手,请各位大侠
发表于 2013-12-20 23:22:01 | 显示全部楼层 |阅读模式
入affiliate行业几个月了,买了不少教程,走了不少弯路,但也学习到了不少东西。最后来到这个论坛,真心喜欢,各位大神都很慷慨地分享了很多知识,如乐乐老师,月光飞燕。
看了月光飞燕的教程后很受鼓舞,决定静下心来做亚马逊利基站。个人买过两个国外seo的教程,但觉得月光飞燕的教程是最详细最全面的,不仅有原理性的分析,还有精彩真实案例,让我对整套流程以及每个细节都有更深入的了解。
我将整个过程分为三大块,选产品和利基础及分析seo竞争,建站写产品review,外链建设。
对前两块都有一定的了解和基础,觉得核心还是要写出有价值的review才能为访客创造价值,引导购买。最近的计划是把教程全部看过,同时不断提高英文写作水平,就从5篇亚马逊产品review开始作为练手。
产品review会陆续发表在这里直到下周4全部写完。模板是写作教程rapid fire writing,觉得很适合自己,难度较低。目标是写作能模式化,量产化。以下的review 都是我随便选的,用来练习写作的,并不打算做这些niche
请大家多指教,共同进步。
BTW,加点T币呗,很难赚啊……
另外,你们都懂的,新人需要鼓励,本人具备一些英语基础,还在不断提高中。看过小弟的review的前辈能否告诉小弟,以小弟目前的写作水准, 能否写出能盈利的review?有什么建议那就更好了,谢谢。
第一个产品:婴儿监视器http://www.amazon.com/Infant-Optics-Digital-Monitor-Vision/dp/B0052QYLUM/ref=cm_cd_ql_qh_dp_t
Infant Optics DXR-5 2.4 GHz Digital Video Baby MonitorReview
-Is it a great baby monitor that’s well worth the money?
If you ever knew anything about being a mother, one of them must be how unsettled and nervous the mothers feel when they have to be away from their babies for a while. Theyneed to make sure that their babies are ok and safe. They are concerned withtheir babies all the time. So a portable and reliable baby monitor with voiceand video detection would calm the mothers down to some extent by providing comprehensive real-time status of their babies wherever they are in the house. Since many ofmy female friends are getting pregnant this year, I thought an easy-to-use and portable monitor would be a great present that would help a lot after they give birth to the babies. So I just do a lot of research on Amazon and some profession forums to find out some cost effective monitors that would be well worth the money,which turns out to be Infant Optics DXR-5 2.4 GHz Digital Video Baby Monitor.
Simplicity design & Easy to use
As you can see,the compact design surrounded by blue and white color plastic looks really cute.It’s such a lightweight gadget that you can take along without feeling it in your pocket or on your hand, ’cause it’s less than 1 pounds. Together with its right size that just fits in your palm, I think it can qualify as “portable”. There are only 5 buttons on the monitor unit and one on the camera, including power buttons. I don’t think any average human being would have trouble using it.
Reliable & secure wireless network
The Infant Optics DXR-5 uses aFHSS wireless communication technology that is pretty safe and highly anti-interference.Like wifi, it works on a 2.4G frequency range and is totally harmless to humanbody like wifi does. Besides, it’s the two signal can stay cool with each other.There won’t be and signal interference between two of them. The communication distance between the camera and the monitor unit is up to 280m in the open area without obstruction. There is signal attenuation indoor when it’s passing the floors and the walls, but the distance can still be up to 50m in the house. I bet you won’t stay so far away from your sweetheart, will you?
Voice Activated & power save mode
The monitor unit equips with a long-lasting 900mAh Li-on battery.It can work along without the original A/D power adapter for up to 6-8 hours inbest condition according to some customer’s review on amazon. Anyway, who likes to be limited by a stupid A/D power adapter? The DXR-5 does provides a power savemode while in which you still can be alerted by any sound the babies produce.The monitor unit will shut its circuit system down to sleep mode if it keeps hearing no voice for 3 minutes, and it will ‘wake up’ and get back to work once it receives any voice from the camera under this mode. This function can be toggled on or off by a button. It’s up to you.
Other features & specification
1. Infrared Night Vision. Thecamera will automatically switch to Night Vision mode when the optical sensor built in the camera detects no lights in the room. It offers 5m visual range by radiating invisible infrared which can still be seem by the digital camera.
2. White Noise Suppression
The monitor unit has some white noise suppression function so it won’t generate ‘clickingnoise’ to annoy people like some other baby monitor does.
3. Compatible with extra cameracapability
DXR-5 monity unit supports up to 4 cameras simultaneously.By pushing a small button on the monitor, you can switch to any camera view.
4.  Super easy to set up
Simply plug the adapters in the cameraand the monitor, then you’re good to go.
click to learn more..........
Customer review & Scores
The Infant Optics DXR-5 2.4 GHzDigital Video Baby Monitor won’t be complete without customers’ review from Amazon.It get 4 stars out of 5 in 2000+ customers. More than half of them give it 5stars. Most of them did tell that it does a good job and give it high phrase.
Any complain ?
Some people said that the tactility of this baby monitor feels kind of cheap because it’s made of lightweight plastic. Well I gotta say there are better baby monitors out there on Amazon, much expensive either. People can choose according to their financial situation. But Infant Optics DXR-5 baby monitor is well worth the money at the price of $100. It well meet most people’s needs.
参与人数 10e币 +48 收起 理由
龙腾山河 + 2
帝尧故里 + 3
幽兰百合 + 2 鼓勵
uper + 2 鼓勵
newinsh + 2 認眞參與
jayhkun + 2 鼓勵
jinking + 5 鼓勵
baron + 1 送花花~~~
月光飞燕 + 27
btlzzdl + 2
发表于 2013-12-20 23:34:27 | 显示全部楼层
这个词你很难上第一页的,都有四,五个大商家排在前了
 楼主| 发表于 2013-12-20 23:35:10 | 显示全部楼层
发表于 2013-12-20 23:47:01 | 显示全部楼层
多编一些个人实战部分,虽然你没有,但是这部分访客是最喜欢的
就是你使用后的效果
自己鼓励自己才是本质,有英语基础的你,已经入门了,后面的要慢慢多学习与改进
发表于 2013-12-20 23:50:46 | 显示全部楼层
厉害,英语水平好就是很好的基础
发表于 2013-12-21 00:04:33 | 显示全部楼层
好啊,可以跟着你学改写了
发表于 2013-12-21 08:05:32 | 显示全部楼层
写的很不错啊,措词都很有深度。很佩服。
发表于 2013-12-21 09:09:08 | 显示全部楼层
楼主写的不错呀 谢谢分享你的想法了 不过这个产品可以写的点 我认为就在红外探测及白噪声抑制 你没有发挥呀
发表于 2013-12-21 09:22:19 | 显示全部楼层
写这样一篇Review要用多长时间呢?自己写review的话,效率时很关键。
 楼主| 发表于 2013-12-21 10:02:09 来自手机 | 显示全部楼层
海淘饭 发表于 2013-12-21 09:09
楼主写的不错呀 谢谢分享你的想法了 不过这个产品可以写的点 我认为就在红外探测及白噪声抑制 你没有发挥呀 ...
是阿,红外该放前面的,但我怕太长了。下次注意,谢谢了。
 楼主| 发表于 2013-12-21 10:03:02 来自手机 | 显示全部楼层
我目前大概三个小时可以写出来。应该可以再加快。模式化是关键。
发表于 2013-12-21 11:15:57 | 显示全部楼层
楼主英语水平真心不错呀!
发表于 2013-12-21 11:32:03 | 显示全部楼层
太强大了,估计一般人没办法自己写这么长的文章
it's not that as you think  发表于 2013-12-21 23:30
发表于 2013-12-21 11:56:02 | 显示全部楼层
楼主英语真不错,加分鼓励了
发表于 2013-12-21 18:01:13 | 显示全部楼层
看上去真的很不错,LZ对于那些不认识的单词或者不理解的技术性的句子是怎么处理的呢?
发表于 2013-12-21 20:14:41 | 显示全部楼层
amazon写review能赚钱?请问哪里去申请账号?
发表于 2013-12-21 20:21:07 | 显示全部楼层
好啊,可以跟着你学改写了
lliang1982 + 2
 楼主| 发表于 2013-12-21 23:28:22 | 显示全部楼层
就是你使用后的效果
谢谢月光。以后我会发一些实战的帖子。
 楼主| 发表于 2013-12-21 23:34:18 | 显示全部楼层
这些我觉得不是问题。用百度翻译一下再参考
 楼主| 发表于 2013-12-21 23:36:37 | 显示全部楼层
jayhkun 发表于 2013-12-21 11:56
楼主英语真不错,加分鼓励了
谢谢啦:):):):):)
GMT+8, 2025-4-19 10:23
