查看: 1542|回复: 9
每日IM文章阅读 2014.1.6 《蜂鸟带来的长尾词变化》
发表于 2014-1-6 22:32:49 | 显示全部楼层 |阅读模式
标题:How Google is Changing Long Tail Search with Hummingbird Update?
中文:蜂鸟带来的长尾词变化
文章网址: http://bloggerspassion.com/how-google-is-changing-long-tail-search-with-hummingbird-update/
改写小练手
  1. This all happened because till that point, the algorithms used by Google didn’t understand the entered phrase as a whole, but it tried to break down the phrase into smaller parts and then look for it in fragments on a website.
发表于 2014-1-7 00:01:22 | 显示全部楼层
支持下乐乐老师。。希望自己早点实现可以自己改写英文文章。。
发表于 2014-1-7 09:26:27 | 显示全部楼层
乐乐,这个帖子的意思是说,你用那个改写助手自动改写文章后的样子吗?
不是,改写助手能自动分析。。。不能自动改写,那个是原文  发表于 2014-1-7 20:20
发表于 2014-1-7 09:50:21 | 显示全部楼层
This is because the algorithms of Google weren't able to understand the entire phase entered by the user in the search box like human being does. Instead, it tried to look for fragments of the phase broken down by itself on a website.
以后的阅读训练就跟乐乐混了。
改写得很好啊 是乐乐改的学员吗 兄弟  发表于 2014-1-7 20:20
乐乐 + 3 認眞參與
发表于 2014-1-7 09:57:56 | 显示全部楼层
If you search for a mobile phone on Google, you are certain to get one link from Amazon, one from Cnet, one from Engadget, one from Gsmarena, and one from Phonearena. Irrespective of your efforts, it’s simply next to impossible to defeat these rivals.
蜂鸟更新后以后分析竞争程度,看到首页全是亚马逊沃尔玛之类的是不是很绝望
发表于 2014-1-7 12:05:38 | 显示全部楼层
This all happened because Google's previous algorithms tried to break down the whole entered phrase into smaller parts so that it's able to look for it on a website in fragments since it can't understand the long phrase which was entered by a user as a whole till that point.
不通顺
entered phrase 改成 phrase entered; till that point 这个时间状语,最好放到最前面,因为这个时间需要结合上下文,而不是具体时间  发表于 2014-1-7 20:23
发表于 2014-1-7 12:48:05 | 显示全部楼层
跟着大神们学习不会错,阅读有些难度,改写更难
发表于 2014-1-7 22:38:41 | 显示全部楼层
是啊,刚成为学员不久,哈哈,qq上的too simple
发表于 2014-1-10 14:45:45 | 显示全部楼层
中文:蜂鸟带来的长尾词变化
发表于 2014-3-31 18:46:10 | 显示全部楼层
感谢分享!如果一个niche站比较有效果 那当然是多做几个了....
GMT+8, 2025-4-17 02:37
