查看: 621|回复: 3
Google Cutts: Links From Press Releases Won't Help
发表于 2014-3-9 09:51:51 | 显示全部楼层 |阅读模式
网上看到这个。2012年的老文章了。
比较疑惑。在我心中Press Release一直是那种最高大上、最有效的外链了。怎么就突然 won't Help了
原文如下:
An old fashion and sometimes often used method today, to get links to your web site, is to use press releases with embedded links in those releases.
So you'd contract a press release distribution company and make sure that the content of the release have links to your web site. That release would hopefully be syndicated by other news outlets and those outlets will keep the links intact.
Matt Cutts of Google said in a Google Webmaster Helpforums that links from press releases shouldn't have a positive impact on your rankings.
Matt wrote:
Now, when you do press releases, it might get your web site in front of the eyes of bloggers, reporters and others, where what they write or link to may have an impact on your rankings. But the links within the releases themselves, Google says - they won't benefit your rankings.
参与人数 2e币 +2 收起 理由
ioioio2 + 1 有見地
jkloli + 1 認眞參與
发表于 2014-3-9 11:38:12 | 显示全部楼层
他的意思同样权重的网站,PR站和非PR站,给你的排名影响是一样的
 楼主| 发表于 2014-3-9 12:34:29 | 显示全部楼层
发表于 2014-3-9 16:56:42 | 显示全部楼层
五年前的文章,现在还有效吗?谷哥算法更新了,情况是否有变化了?
GMT+8, 2025-4-20 17:55
