楼主 |
发表于 2014-3-26 20:50:07
显示全部楼层
我看到勇士论坛上 有人推荐name.com, 原帖如下,应该比较好用吧。
I have used namecheap in the past and they are on my NO NEVER AGAIN list. They are not an ICANN accredited registrar. They are actually a reseller for eNom, so when you do a whois it shows it’s registered through namecheap AT eNom.
When you do anything there it has to get passed on to eNom and I experienced delays and failures their interface with eNom. When you think you have paid to register a domain an namecheap, if somebody registers it elsewhere before they successfully pass the information to eNom, you are out of luck on the domain name, but they do give you a prompt refund.
As far as godaddy, just google Mike Filsaime godaddy and you'll get a couple of screenfulls of how godaddy will disable your domain for one complaint, even if unfounded.
My recommendation is name.com. I have been using them for about three years and never had any problems. I have used nodaddy, namecheap and netfirms in the past and now have my 50+ domains at name.com
When I checked their .com: $8.25 for transfers --- $9.25** for new and renewals they have a free privacy if you use a coupon code. "PRIVACYPLEASE"
**When you are buying anything there check at http://www.retailmenot.com/view/name.com for current discount codes. You cannot use 2 coupons in one transaction, so buy/renew a domain with a coupon and then immediately go back and get the whois privacy.
