查看: 1178|回复: 6
推一个社会化分享插件MoreSharesForYou
发表于 2014-4-4 22:48:51 | 显示全部楼层 |阅读模式
不知道有用过的没有,类似于微博上的互粉团,但是有一套分数计算规则
Description
Do you dream of your content being shared by others?
This is precisely what The MoreSharesForYou Plugin helps you accomplish: increase the number of Facebook Likes and Shares of your posts and pages. Through an ingenious system of content discovery and cross-promotion this plugin is your best WordPress friend when it comes to quickly grow your social-proof button counters, right after publishing your new posts.
The plugin is user-friendly and extremely easy to use: just install it and press the PLAY button for the campaign to start. Then watch your stats increase.
We help WordPress users and Social Media Bloggers to get more Likes and Shares through the Social Exchange - a points-based reciprocal system.
It works like this:
  • when you install the plugin we give you FREE points
  • you spend your points giving them to people sharing your content
  • you get more points by sharing others content
IMPORTANT: You should display the Facebook LIKES button on your shared posts and pages so your audience can see on your website the number of Likes. (Facebook adds the likes and the shares into 1 single metric). This is an important social proof indicator for your readers.
EQUALLY IMPORTANT: Facebook and the other social networks "count" your likes/shares in relation to a certain URL. Please make sure you have the final URL Pretty Permalink in place before starting a campaign. Otherwise, if you change the URL later, Facebook will not display your previous like numbers.
It's a WASTE OF MONEY AND TIME to have a good website/blog that nobody is seeing or reading.
The MoreSharesForYou Plugin helps you achieve 2 goals:
  • distribute your content
  • show the world your content is liked (distributed)
明白了吧。。 那就也都装上大家互点赞吧
另一方面,点赞或share别人网页的时候,看看别人在做什么niche也是很有意思的事情
如果你觉得有用,请加T币,评分加币不会减少自己的T币,谢谢!
发表于 2014-4-7 23:08:30 | 显示全部楼层
这个和addmefast有什么区别
发表于 2014-4-8 13:38:31 | 显示全部楼层
这个软件没有用过
发表于 2014-4-8 20:13:12 | 显示全部楼层
插件在哪下载呀
发表于 2014-4-8 22:00:33 | 显示全部楼层
插件在哪下载呀
 楼主| 发表于 2014-4-8 22:26:47 | 显示全部楼层
一定要贴出下载地址吗?在WP后台插件管理搜一下插件名不就OK了?!
 楼主| 发表于 2014-4-8 22:28:05 | 显示全部楼层
addmefast没用过。效果怎么样?
这个插件貌似每天分享数量有一定的限制,偶尔会有No articles available!的情况出现,
GMT+8, 2025-4-17 21:15
