查看: 3286|回复: 8
分享一个pbn的域名选择知识
发表于 2014-4-9 14:19:31 | 显示全部楼层 |阅读模式
  • Relevance
    • Highly or moderately relevant. Is it conceivable that this website would naturally link to your money site? If you think it would conceivably naturally link to your site than it is moderately relevant.  If there is no way it would link to your site unless completely randomly I do not consider it relevant.
  • Metrics
  • Spam Check
    • Check anchor text for Porn, Pharmaceuticals, Poker or foreign language anchor text in Majestic SEO – If any signs of this kind of anchor text do not buy!
    • Natural Profile (no SEO) – Check backlinks for signs of blog network links, comment spam or directory spam – Use your discretion but if it looks like someone was doing low value SEO on the domain do not buy it!
    • Does the exact match anchor text look natural? Below 15% at least – If no Do Not Buy
    • Review website in Archive.org and see if the domain had content not related to the domain name – If the content does not make sense with the domain name it means it was already used as an expired domain (poorly used) – Do not buy it!
  • Redirection/Duplicate Check
    • Check if the site was last redirected to a new site by checking the most recent page in Archive.org to see if it was being redirected to a new site. If it was redirected before expiring then most of the juice seems to stay with the redirection. Do not buy.
    • Also check if all the old content has been moved to a new site – this may mean even though the redirection did not show up in Archive.org they did a 301 redirect on the old URL and Google has passed all the link juice to the new site. Use copyscape.com or this free alternative for this.
  • Registrar History
    • Check the registrar history if it has been registered and dropped multiple times you need to be confident it was not abused by checking it in Archive.org. You can check the number of times a site has been registered by visiting - http://whois.domaintools.com
参与人数 2e币 +6 收起 理由
forwhatah + 2 楼主,this free alternative的链接错了.
晕蛋疯亲 + 4 挺不错的!
 楼主| 发表于 2014-4-9 14:22:56 | 显示全部楼层
简单翻译一下
1、相关性
和主站需要有一定相关性
2、硬性参数
pr、pa、da等
3、spam检测
有没有被滥发
4、301之类的检测
内容是不是重复的,网站是不是重定向
5、注册历史
反复注册总归不是好事
发表于 2014-4-9 14:55:34 | 显示全部楼层
说了一堆 新人没明白  pbn 是什么意思
发表于 2014-4-9 15:16:51 | 显示全部楼层
发表于 2014-4-9 15:19:21 | 显示全部楼层
buffett 发表于 2014-4-9 15:16
private blog network,多撸多精采。
秒懂 感谢  总结的非常好 如果记住以上发链接就非常好了
发表于 2014-4-10 11:17:00 | 显示全部楼层
发表于 2014-4-10 11:55:50 | 显示全部楼层
这个还是需要资金支持吧
发表于 2014-8-21 16:33:01 | 显示全部楼层
感谢分享 正需要这方面的东西
发表于 2014-12-5 11:13:07 | 显示全部楼层
没有翻译不好评啊,看起来太累
GMT+8, 2025-4-25 08:23
