查看: 840|回复: 9
codecanyon-simple-file-sharer-1.63 正版自购
发表于 2014-5-1 21:31:59 | 显示全部楼层 |阅读模式
http://codecanyon.net/item/simple-file-sharer/4562987
DEMO
http://codecanyon.net/item/simple-file-sharer/full_screen_preview/4562987
Features        - single file upload and sharing
- multiple files upload and sharing (since 1.4)
- drag and drop or just select file(s)
- autoupload
- progressbar and progress numbers
- mail sharing, ability to send to more than one receipient by closing the success message
- admin interface with dashboard, various charts and possibility to manage uploaded files
- ready to use ajax contact form
- built on bootstrap (bootswatch’s cerulean)
- responsive (since 1.4)
- ready to use faqs module
- easy to change frontend languages (English, Deutsch (Sie), Deutsch (Du) included)
- possibility to block list of extensions
- possibility to allow list of extensions
- possibility to disable direct file downloads (IP or session based), or to disable the protection
- display expiration date of files on download or deletion page
- autodelete depending on age
- autodelete depending last download (since 1.2)
- countdown X seconds befor download is possible (since 1.2)
- reporting files function (since 1.2)
- image preview of uploaded images (since 1.2)
- bandwidth throtteling on downloads (since 1.3)
- supporting mod_xsendfile (since 1.3)
- maximum age of downloads by uploader (since 1.6)
- maximum number of downloads by uploader (since 1.6)
谁能把这个安装在lnmp环境,正常运行,帮我解决该问题的,日后升级可以单独得到升级包。谢谢!
https://www.dropbox.com/s/5y50dhvkyqw3dfs/codecanyon-simple-file-sharer-1.63.zip
 楼主| 发表于 2014-5-1 21:35:07 | 显示全部楼层
PS:帮我解决的人,还可以任选theme-junkie.com 的主题一个,个人是终身用户。
发表于 2014-5-1 21:42:41 | 显示全部楼层
这个东东有什么用处?
发表于 2014-5-1 22:05:12 | 显示全部楼层
theme-junkie.com上的主题 貌似我很久就有打包下载过
发表于 2014-5-1 22:09:35 | 显示全部楼层
发表于 2014-5-1 22:12:13 | 显示全部楼层
Installation
- Unzip and upload files of the htdocs to your webserver into the directory you like to have SFS installed to.
- Take a look to you config.php and change database credentials, user, password, secretKey and other things you wanna change (more infos below)
- Point your browser to your installation and follow the instructions.
- Open your .htaccess and update the Error404 Part
    ErrorDocument 404 /demos/SimpleFS/notfound
 楼主| 发表于 2014-5-1 22:31:00 | 显示全部楼层
xaut3 发表于 2014-5-1 22:12
Installation
simple-file-sharer 作者是为apache设计的,但我问过作者是否能够安装在nginx上,他说能,但是没有测试过,购买后,他又叫我自己去搞定。晕死。
不知道你能帮忙搞定,谢谢!
发表于 2014-5-1 23:25:10 | 显示全部楼层
woi911 发表于 2014-5-1 22:31
simple-file-sharer 作者是为apache设计的,但我问过作者是否能够安装在nginx上,他说能,但是没有测试过 ...
会报错,还是?
 楼主| 发表于 2014-5-2 10:21:01 | 显示全部楼层
xaut3 发表于 2014-5-1 23:25
会报错,还是?
恩,所以我才发求助
发表于 2014-5-2 14:32:36 | 显示全部楼层
报什么错误发出来看看
GMT+8, 2025-4-20 12:40
