查看: 887|回复: 11
Amazon 四个月没付佣金了!怎么回事?
发表于 2014-5-8 23:09:19 | 显示全部楼层 |阅读模式
Amazon 四个月没付佣金了!最后一次付的时间是2014/1/30,接下来的四个月都没有付,怎么回事呢?我看了设置,选的GC啊,不是过15刀就付的么?还是有新的条款没注意到?
还有UK帐号付了没收到,给客服说了,回答得牛头不对马嘴,同样的事,US一反映就重新发了。
发表于 2014-5-9 08:37:24 | 显示全部楼层
难道是没有佣金收入了,你查下成交量啥的
 楼主| 发表于 2014-5-9 09:12:08 | 显示全部楼层
发表于 2014-5-9 10:33:45 | 显示全部楼层
不会号被K了吧 看看有没有邮件提醒
 楼主| 发表于 2014-5-9 11:48:37 | 显示全部楼层
jayhkun 发表于 2014-5-9 10:33
不会号被K了吧 看看有没有邮件提醒
后台都可以上得去,每月还自动结算的,就是没有付款,我选的GC,以前一直正常,每月都能收到,看了amazon发的所有邮件,没有说被封
发表于 2014-5-9 13:17:02 | 显示全部楼层
前段时间有个税收方面的邮件你看了哇,你的回复邮件不然一直都是绑定状态。
pootor + 1 送花花~~~
 楼主| 发表于 2014-5-9 13:28:11 | 显示全部楼层
应该是这个没有回复吧,当时看了,还标记了重要邮件,当时没来得及回复,我就是想起来有个什么通知的,忘了,谢谢提醒!
发表于 2014-5-9 13:57:08 | 显示全部楼层
50 刀  起付
 楼主| 发表于 2014-5-9 14:54:21 | 显示全部楼层
xaut3 发表于 2014-5-9 13:57
50 刀  起付
不是这个问题,都几百刀了,还没付,应该是一个上报税收的邮件没有回复造成的。
发表于 2014-5-9 15:35:12 | 显示全部楼层
哪里看是不是绑定状态啊?
所有的账号都得回复那封邮件?
发表于 2014-5-9 15:59:48 | 显示全部楼层
几月份的邮件?哪个国家的?我怎么没有收到邮件呢?
 楼主| 发表于 2014-5-9 23:31:40 | 显示全部楼层
2014/01/22的邮件,amazon.com 的。主题为:Important Request: Amazon Associates Tax Information Request
Hello, Our records indicate that you received payment(s) for services provided as part of the Amazon Associates program. The US Internal Revenue Service requires Amazon to ask our Associates where their Associate services were performed (either within or outside the US) in order to ensure appropriate US tax reporting. Failure to respond to the inquiry may result in the application of an IRS rule which presumes that the services were performed in the US, resulting in US 1099 tax reporting on service income. This reporting isn't necessary if the services are performed outside the US, so it's important that you respond to this inquiry as soon as possible. Please send all the required information below via email to: [email protected] If you have multiple Associate accounts (store ID 's), please provide one statement only, applicable to all of your related accounts (store ID's). 1. Are you located outside of the United States when conducting business with the Amazon Associate Program? (Place an 'X' in the appropriate box)  ( )YES  ( )NO 2. If no, please answer the question below. (If yes, please stop here and send your response via e-mail) For each of the following calendar years, please indicate the approximate percentage of time during each year that you were physically located inside the United States and physically located outside the United States when your services for Amazon Associates were performed. Percentage of Time Located Inside the United States performing services for Amazon Associates: 2010: 2011: 2012: 2013: Percentage of Time Located Outside the United States performing services for Amazon Associates: 2010: 2011: 2012: 2013: If you have any questions, please contact us at the email address mentioned above.Sincerely,The Amazon Associates Team
GMT+8, 2025-2-24 19:00
