楼主: Lebron.
小Niche,大流量 - Lebron实战案例分享
 楼主| 发表于 2014-5-14 20:48:02 | 显示全部楼层
 楼主| 发表于 2014-5-14 20:48:31 | 显示全部楼层
billy 发表于 2014-5-13 15:18
月搜索几百的词为什么有这么大流量?
相关关键词,长尾关键词有很多...
billy + 2 原来如此
 楼主| 发表于 2014-5-14 20:49:00 | 显示全部楼层
jenny007 发表于 2014-5-13 15:41
我想知道楼主是在哪外包的文章?首页2000字的文章也是外包的吗?
各个外包平台找人,时间久了有一些固定的写手长期合作。
 楼主| 发表于 2014-5-14 20:49:20 | 显示全部楼层
inspired 发表于 2014-5-13 16:10
请问这个流量分析是哪个软件或平台?
这个是CLICKY
 楼主| 发表于 2014-5-14 20:50:03 | 显示全部楼层
sure15 发表于 2014-5-13 19:48
谢谢楼主分享。
1.楼主在哪里外包文章?
2.为什么average actions只有1.2,但是跳出率却那么低?
1.各个外包平台找人,时间久了有一些固定的写手长期合作。
2.跳出率有两个影响因素,平均浏览页面和某一个页面停留时长。
sure15 + 2
发表于 2014-5-14 21:37:27 | 显示全部楼层
2.跳出率有两个影响因素,平均浏览页面和某一 ...
如果访客只访问了一页,但是停留在多时间应该也是跳出率100%。clicky应该检测不出来停留时间。
发表于 2014-5-14 21:57:00 | 显示全部楼层
楼主执行力很好,目标性也很强啊
 楼主| 发表于 2014-5-14 22:00:48 | 显示全部楼层
这是Clicky对于跳出率的官方解释。付费用户的统计数据中,满足二者其一的不算入“跳出”:一是访问页面大于1,二是单个页面停留时长大于30秒。
Bounce rateThe bounce rate tells you how engaged your visitors are with your site, on a general level.
Clicky's bounce rate is much different from any other service - in a good way. All other services define a bounce as simply any visitor who viewed only a single page. With Clicky, though, our tracking code will continue to ping our servers while a visitor sits on a single page. This gives us a much more accurate picture of how long the visitor was actually on your site.
Our bounce rate takes this into account. A visitor will only count as a bounce on Clicky if they only view a single pageand they were on your web site for less than 30 seconds. We figure, if someone is there for at least 30 seconds, they were at least mildly engaged and should not count as a bounce.
IMPORTANT: Because pinging can take up a lot of extra bandwidth, a paid account is required for this to work. Otherwise, our bounce rate will only be based on single page view visits.
sure15 + 2
发表于 2014-5-14 22:13:28 | 显示全部楼层
Lebron. 发表于 2014-5-14 22:00
这是Clicky对于跳出率的官方解释。付费用户的统计数据中,满足二者其一的不算入“跳出”:一是访问页面大 ...
谢谢,抱歉,今天的分用完了。。。都加给你了,太给力了!
发表于 2014-5-14 22:16:39 | 显示全部楼层
Lebron. 发表于 2014-5-14 20:47
是自己搭配的,某一个mobile的theme和一个AD优化plugin
请教兄弟,你是指同一网站做了两个模板吗?Pc主题一个,mobile主题一个?
如果用responsive 的主题是不是可以直接解决pc与mobile的兼容问题呢?
发表于 2014-5-14 22:26:57 | 显示全部楼层
楼主,可以分享一下  流量的国家分布,和来源分布吗?都是SE流量?
 楼主| 发表于 2014-5-15 06:23:56 | 显示全部楼层
如果用responsive 的主题是不 ...
当然可以,还更省事省钱。
 楼主| 发表于 2014-5-15 06:24:23 | 显示全部楼层
基本都是美国流量。不是。
发表于 2014-5-15 11:38:22 | 显示全部楼层
请问LZ有用过抢注服务抢过期域名没有
发表于 2014-5-17 00:06:09 | 显示全部楼层
不错 学习一下,那个 如何找nich呢?
发表于 2014-5-19 16:56:42 | 显示全部楼层
Infolinks 这个事什么意思呀
发表于 2014-5-19 22:09:35 | 显示全部楼层
lz超级super棒,学习了!!!
 楼主| 发表于 2014-5-19 22:21:45 | 显示全部楼层
HappySky 发表于 2014-5-15 11:38
请问LZ有用过抢注服务抢过期域名没有
没有哈,都是自己来。
发表于 2014-5-20 22:54:22 来自手机 | 显示全部楼层
挺是佩服,多多指教哦!
发表于 2014-5-20 23:17:09 | 显示全部楼层
谢谢分享,很详细,有参考价值
GMT+8, 2025-4-16 08:12
