查看: 1183|回复: 8
谁了解这个伪原创软件的Kontent machine 3
发表于 2014-6-2 14:22:42 | 显示全部楼层 |阅读模式
这个软件原理就是输入一个关键词。可以为你构建海量的文章、生产的文章质量还行、COS上面只有极少或者没有任何文章和构建的文章相似、貌似非常强大、谁用过的说说呀!
发表于 2014-6-2 14:49:38 | 显示全部楼层
能读吗?可以阅读吗?
发表于 2014-6-2 17:13:04 | 显示全部楼层
没用过  介绍一下呗.......
发表于 2014-6-2 19:15:44 | 显示全部楼层
看过kontent machine出来的文章,个人感觉相比较article builder生成的文章逻辑性差一些但是原创度要好一些,而article builder 正好相反,最后还是要看个人喜好了!下面是kotent machine 生成的文章,楼主可以看一下(只是截取了一部分)
[TITLE]Bass Fishing Tips And Tactics[/TITLE]
<center><img src="http://www.lakeonline.com/fishinhole/fishing-tips-top.gif" width="450" /></center>
It's well known that it can be tougher to catch these glorious fish during this use of year, so care needs to be taken to try different tactics from what worked during the Springtime if your normal walleye techniques aren't bringing the particular quantity or measurements of fish you drive.
This time of the year can be frustrating or wonderful with bass swimming. The weather plays a huge role in this, of course, but you do not have to let the elements keep you from potentially catching a trophy bass. For you to use the actual time of day to fish will aid you to catch far. There is no need at this time to get up early or stay out too late to catch bass. You need to fish down the middle of the day when is actually usually warmest. The next step is that bass will you have to be likely to bite.
Finally, within the fishing with bait the right hooks want to be employed. First off, your hooks are being very nippy. This means that your hooks in order to changed or sharpened after they've been used temporarly while. Secondly, when fishing with live bait you should use gag hooks. This is also true if you fish with live worms or minnows. Gang hooks are just a pair of small hooks tied in tandem, let an a little more natural demo. Heck, you want your live bait to look as as well as it looks in nature as possible, right? Well, gang hooks are proven methods to accomplish this task.
发表于 2014-6-2 20:11:05 | 显示全部楼层
article builder 也别直接用。能识别。
 楼主| 发表于 2014-6-2 20:37:18 | 显示全部楼层
wise2013 发表于 2014-6-2 19:15
看过kontent machine出来的文章,个人感觉相比较article builder生成的文章逻辑性差一些但是原创度要好一些 ...
谢谢!我最近打算几个最新的伪原创软件都试试。
tbs  发表于 2014-8-1 09:43
发表于 2014-6-2 20:52:24 | 显示全部楼层
以前用来做外链文章用的。。。。应该问题不大
发表于 2014-6-2 21:08:42 | 显示全部楼层
以前是问题不大
但是有些niche现在直接用,效果就不行。
发表于 2014-7-24 14:23:10 | 显示全部楼层
这软件怎么收费啊?~~~~~~~~~~~~~~~~~~~~~
GMT+8, 2025-4-12 13:20
