查看: 984|回复: 3
注册亚马逊ses的时候遇到问题
发表于 2014-9-23 23:22:16 | 显示全部楼层 |阅读模式
Your Amazon SES account has "sandbox" access in region US West (Oregon). With sandbox access you can only send email to the Amazon SES mailbox simulator and to email addresses or domains that you have verified. Learn more. Can't find your existing account settings? Your account may be set up in a different AWS region. Try switching regions in the upper right corner of the console.
    Request Production Access
现在怎么办?
发表于 2014-9-24 01:01:54 | 显示全部楼层
从这段话看 你可以在控制台右上角把地区改一下  前面Oregon那个已经被沙盒了
 楼主| 发表于 2014-9-24 17:20:28 | 显示全部楼层
还是不行,改了也是显示一样的文字,但是地区改成相应的文字
发表于 2014-9-24 18:36:00 | 显示全部楼层
To remove the restriction on recipient addresses and increase your sending limits, you can apply for production access using the following instructions.
Note
Amazon SES has endpoints in multiple AWS regions. You must request production access separately for each region you want to use. For information about using Amazon SES in multiple AWS regions, see Regions and Amazon SES.
To request production access to Amazon SES
    Log into the AWS Management Console.
    Go to http://aws.amazon.com/ses/fullaccessrequest/ and open an SES Production Access case.
    We will respond to the case after reviewing your request. Please allow one business day for processing.
按照红色部分申请production access,注意不同的地区。一个工作日后他们会处理。
如果还有不懂的可以PM。
可我现在还没有PM权限,要不给我加点分吧,哈哈
GMT+8, 2025-4-14 19:28
