查看: 1509|回复: 2
SSH bash紧急安全补丁--linux全系列系统最终修复解决方案
发表于 2014-9-27 22:51:19 | 显示全部楼层 |阅读模式
漏洞详情页面:http://seclists.org/oss-sec/2014/q3/650
漏洞级别:非常严重
漏洞信息:
1.测试是否存在漏洞,执行以下命令:
    env t='() { :;}; echo You are vulnerable.' bash -c "true"
如果显示You are vulnerable,很遗憾,必须立即打上安全补丁修复
如果出现提示
bash: warning: t: ignoring function definition attempt
bash: error importing function definition for `t'
表示已经打好补丁
记得升级打好补丁后,重启系统。
2.修复漏洞办法 更新来自阿里云的方法:http://bbs.aliyun.com/read/176977.html
    centos:
    yum -y update bash
    ubuntu:
    14.04 64bit
    wget http://mirrors.aliyun.com/fix_stuff/bash_4.3-7ubuntu1.1_amd64.deb && dpkg -i bash_4.3-7ubuntu1.1_amd64.deb
    14.04 32bit
    wget http://mirrors.aliyun.com/fix_stuff/bash_4.3-7ubuntu1.1_i386.deb && dpkg -i  bash_4.3-7ubuntu1.1_i386.deb
    12.04 64bit
    wget http://mirrors.aliyun.com/fix_stuff/bash_4.2-2ubuntu2.2_amd64.deb && dpkg -i  bash_4.2-2ubuntu2.2_amd64.deb
    12.04 32bit
    wget http://mirrors.aliyun.com/fix_stuff/bash_4.2-2ubuntu2.2_i386.deb && dpkg -i  bash_4.2-2ubuntu2.2_i386.deb
    10.× 64bit
    wget http://mirrors.aliyun.com/fix_stuff/bash_4.1-2ubuntu3.1_amd64.deb && dpkg -i bash_4.1-2ubuntu3.1_amd64.deb
    10.× 32bit
    wget http://mirrors.aliyun.com/fix_stuff/bash_4.1-2ubuntu3.1_i386.deb && dpkg -i bash_4.1-2ubuntu3.1_i386.deb
    debian:
    7.5 64bit && 32bit
    apt-get -y install --only-upgrade bash
    6.0.x 64bit
    wget http://mirrors.aliyun.com/debian ... %2bdeb6u1_amd64.deb &&  dpkg -i bash_4.1-3+deb6u1_amd64.deb
    6.0.x 32bit
    wget http://mirrors.aliyun.com/debian ... 3%2bdeb6u1_i386.deb &&  dpkg -i bash_4.1-3+deb6u1_i386.deb
    opensuse:
    13.1 64bit
    wget http://mirrors.aliyun.com/fix_stuff/bash-4.2-68.4.1.x86_64.rpm && rpm -Uvh bash-4.2-68.4.1.x86_64.rpm
    13.1 32bit
    wget http://mirrors.aliyun.com/fix_stuff/bash-4.2-68.4.1.i586.rpm && rpm -Uvh bash-4.2-68.4.1.i586.rpm
    aliyun linux:
    5.x 64bit
    wget http://mirrors.aliyun.com/centos ... 33.el5.1.x86_64.rpm && rpm -Uvh bash-3.2-33.el5.1.x86_64.rpm
    5.x 32bit
    wget http://mirrors.aliyun.com/centos ... 2-33.el5.1.i386.rpm && rpm -Uvh bash-3.2-33.el5.1.i386.rpm
补充内容 (2014-10-2 17:37):
http://www.laozuo.org/4071.html    http://www.tennfy.com/2541.html
补充内容 (2014-11-2 16:37):
http://www.hostloc.com/thread-255868-1-1.html
补充内容 (2014-11-12 12:13):
http://www.deepvps.com/linux-bash-vulnerability.html
补充内容 (2014-11-16 23:28):
cenotos重启      service sshd restart  或   /etc/init.d/sshd restart
DeBian重启SSH       service ssh restart    或   /etc/init.d/ssh restart
补充内容 (2014-11-17 21:49):
Linux CentOS修改SSH默认端口http://www.paipat.com/?post=36 http://www.cnblogs.com/ginoz/archive/2012/07/31/2617097.html  http://blog.csdn.net/tianlesoftware/article/details/6201898
liwoonゞ + 2 認眞參與
 楼主| 发表于 2014-9-28 15:29:59 | 显示全部楼层
漏洞级别:非常严重
漏洞信息:
1.测试是否存在漏洞,执行以下命令:
[mw_shl_code=bash,true]env t='() { :;}; echo You are vulnerable.' bash -c "true"[/mw_shl_code]
如果出现提示
表示已经打好补丁
记得升级打好补丁后,重启系统。
centos:
[mw_shl_code=bash,true]yum -y update bash[/mw_shl_code]
ubuntu:
14.04 64bit
14.04 32bit
12.04 64bit
12.04 32bit
10.× 64bit
10.× 32bit
debian:
7.5 64bit && 32bit
[mw_shl_code=bash,true]apt-get -y install --only-upgrade bash[/mw_shl_code]
6.0.x 64bit
6.0.x 32bit
opensuse:
13.1 64bit
13.1 32bit
aliyun linux:
5.x 64bit
5.x 32bit
 楼主| 发表于 2014-9-28 15:54:27 | 显示全部楼层
禁用链接识别
debian:
7.5 64bit && 32bit
6.0.x 64bit
    wget http://mirrors.aliyun.com/debian/pool/main/b/bash/bash_4.1-3%2bdeb6u1_amd64.deb &&  dpkg -i bash_4.1-3+deb6u1_amd64.deb
6.0.x 32bit
[mw_shl_code=bash,true]wget http://mirrors.aliyun.com/debian/pool/main/b/bash/bash_4.1-3%2bdeb6u1_i386.deb &&  dpkg -i bash_4.1-3+deb6u1_i386.deb[/mw_shl_code]
GMT+8, 2025-4-17 21:59
