查看: 952|回复: 9
验证邮箱后,为什么只有放在namesilo 上的站还是打不开
发表于 2014-10-17 22:06:05 | 显示全部楼层 |阅读模式
我的站群里的站,因为域名注册商要求验证邮箱,而我没有及时验证,被停掉了,就是打不开了。后来我都去邮箱验证了一番,有一些可以打开了。但是 就是放到namesilo 上的,虽然经过邮箱验证,但还是打不开,不知道什么原因,只好问namesilo, 但是,他给我的英文答复我看不懂,哪位大侠可以帮忙看下是怎么回事吗?
Hi,
All of your domains use third-party companies for DNS. We therefore have
no control over how/if the sites load. You need to contact your selected
hosting/DNS providers.
You have not setup any of your domains to use us
for DNS. We have absolutely nothing to do with the process of routing
web site or any other requests for your domains. Those things are
handled by the name servers you are using.
You need to contact those
companies with any questions. We are just the registrar for the domains
as you have not selected for us to provide any other services.
On 10/16/2014 9:28 PM, wrote:
> Dear Sir,
> I have recieved an email asking me to verify my email. So does it mean
> that I will be able to open my websites whose domains are with you.
> As to the host, there is no problem.
> Thank you and best regards
> On Sunday, October 12, 2014 9:26 PM, NameSilo Support - 2
> <[email protected]>wrote:
> Hello,
> We have not started verifying WHOIS contact information and will not do
> so for a few more weeks so that is not the cause. It is unfortunately
> not possible to provide more specific support since you did not tell us
> any of the domains in your account, and you email address does not match
> any email for any user in our system.
> The only advice we can give is for you to contact your host and ask why
> your web sites are not working.
> Thanks
> wrote:
> > Hello,
> > The problem is that the websites whose domains are under my namesilo
> > account can't be opened.
> > I tried them all, but none of all can be opened. However, other
> > domains with other domain register can open.
> > It's said that the top domain register will send emails to me to
> > verify if I am the owner...
> > like:
> > "As of January 1, 2014, the Internet Corporation for AssignedNames
> > and Numbers (ICANN) has mandated that all ICANN accredited registrars
> > begin verifying the WHOIS contact information for all new domain
> > registrations and Registrant contact modifications.
> > The following change has been requested to the Registrant contact
> > information for one or more of your domains and requires
> verification:..."
> > If it's not the above reason
> > Could you tell me why only my doamin names with namesilo can't be
> opened?
发表于 2014-10-17 23:15:42 | 显示全部楼层
You need to contact your selected hosting/DNS providers.
你需要联系主机/DNS 服务商。
你的DNS服务器用的不是Namesilo的,去DNS服务器重新设置下,不行的话联系DNS服务商即可。
xiaoyanmi + 1
 楼主| 发表于 2014-10-18 08:35:33 | 显示全部楼层
感谢回复,可是为什么我其他的网站,比如域名放到 namecheap 上,空间用的也不是namecheap,
就可以正常打开呢?
主机就是指空间,对吗,然后 DNS 是不是和空间有关呢,谢谢!
发表于 2014-10-18 08:52:40 | 显示全部楼层
主机和VPS是公寓楼, 包括若干房间[255区255幢255室255号,etc.]
DNS是门牌号码系统,
域名是门牌号码的自定义名称/简称/别称[丽春院, 藏经阁, etc.],
访客根据域名对应的DNS记录找到门牌号才能准确进入某个房间;
xiaoyanmi + 1
发表于 2014-10-18 09:02:58 | 显示全部楼层
就可以正常 ...
主机就是空间。
DNS是domain name system(域名解析系统),作用是将域名指向空间。
域名就是名字,比如eefaq.com, baidu.com 这是域名;
空间是你的服务器所在的IP地址, 比如eefaq.com放在163.202.21.242这个地址上
如果你不用DNS,每次访问TGL时都输入163.202.21.242,多麻烦。输入eefaq.com多方便!
xiaoyanmi + 1
 楼主| 发表于 2014-10-22 21:17:40 | 显示全部楼层
你需要联系主机/DNS 服务商。
”去DNS服务器重新设置下,不行的话联系DNS服务商即可。“
楼上的大侠,就是这一个我不知道怎么操作,
因为站群是别人帮我建立的,
所以我什么都不懂,
现在,我想问的是,
如何知道我的DNS服务商是谁?
发表于 2014-10-22 21:28:38 | 显示全部楼层
我的namecheap , dns是这样的,看图 , 就是用了bluehost的dns.  http://www.eefaq.com/thread-120260-1-1.html
namesilo 后台你能登录的吧,每个选项看。
你直接问帮你弄的那个人,可能是用了第三方的dns.
主机就是指空间,对吗-----------------------------------
楼主,怎么觉得你比小白还小白,这么基础的东西自己都不会,还要掌握在别人的手上,小心被人骗!
xiaoyanmi + 2
 楼主| 发表于 2014-10-22 22:00:55 | 显示全部楼层
我查出来了 是
域名服务器是 NS10.DOMAINCONTROL.COM
这种接下来该怎么办呢,
不会是域名被没收了吧。
发表于 2014-10-22 23:24:31 | 显示全部楼层
xiaoyanmi 发表于 2014-10-22 22:00
我查出来了 是
这种接下来该怎么办呢,
GoDaddy Nameservers
我猜测,那个人买了GoDaddy 的主机建站, 在namesilo dns上用了GoDaddy 的主机的dns 解析.
和我类似, 我买了bluehost 的主机建站, 在namecheap dns上用了bluehost  的主机的dns解析.
GoDaddy 的主机在天朝经常被墙,口碑不好,用代理登录你的网站
网站被墙检测工具 http://hostucan.cn/site-block-checker
回答正确,楼主加分
参与人数 2e币 +2 收起 理由
xiaoyanmi + 1
zhuomuniao + 1 楼主,你知道的太多了
 楼主| 发表于 2014-11-10 22:04:05 | 显示全部楼层
hardrock 发表于 2014-10-22 21:28
我的namecheap , dns是这样的,看图 , 就是用了bluehost的dns.  http://www.eefaq.com/thread-1202 ...
楼上的兄弟,我想请你帮我看看我这几个小站打不开的问题,然后我付给你报酬,我知道你不在乎钱,可是我在乎你花的时间。。。
我自己实在是菜鸟。。。
非常感谢:-)
GMT+8, 2025-4-13 04:42
