查看: 1322|回复: 15
来点压力测试
发表于 2014-11-28 00:58:00 | 显示全部楼层 |阅读模式
http://tgl.lelegai.com/10/?q=juicer
q=任何关键词
每次刷新随机生成一篇文章
采集自 ezinearticles
参与人数 2e币 +2 收起 理由
songsong123 + 1
晕蛋疯亲 + 1 送花花~~~
发表于 2014-11-28 01:25:31 | 显示全部楼层
乐版主,造了一年的文章机器,有什么重大成果 ?
发表于 2014-11-28 01:33:17 | 显示全部楼层
juicer 这个关键词我看的标题是 Juicing Recipes For Better Sex !
榨汁机和伟哥结合在一起,很有创意。
Certain foods contain nutrients that enhance male and female libido. This is particularly important in our era of male and female Viagra and other medications for sexual dysfunction. These prescriptions are quick, short-term fixes, but don't get to the root of the problem, and they come at a cost - not only are they expensive, but they result in a growing list of serious side effects including memory loss, hearing impairment, and vision loss!
So forget the pills and start juicing for a healthy and natural boost to your sex drive and performance! Here's a review of the foods that contain the highest concentration of sexually stimulating nutrients.
哈哈 有缘  发表于 2014-11-28 01:35
 楼主| 发表于 2014-11-28 01:33:32 | 显示全部楼层
发表于 2014-11-28 01:44:53 | 显示全部楼层
就是不睡觉就是任性
发表于 2014-11-28 09:30:11 | 显示全部楼层
乐版,这个神器还能测吗,貌似打开空白啊。
发表于 2014-11-28 10:24:26 | 显示全部楼层
好神器,这是咋实现的
发表于 2014-11-28 10:42:38 | 显示全部楼层
测试了一下
http://tgl.lelegai.com/10/?q=loseweight
How To Lose Weight Without Pain?
Is it possible to lose weight without dieting and exercise? Is there any magic pill that will help you lose weight without any effort?
You know the answer. It is not possible. When it comes to weight loss discussion there is always effort involved. The first thing that comes to my mind is dieting. If I want to lose weight, I must control my cravings. I must do dieting. I should eliminate desserts, chocolates, and cold drinks out of my life. I should do exercise and all that stuff.
Sounds like too much hard work. It is hard and tough. But still there is another path. You cannot lose weight without exercise or proper diet plans but you can do it easily.
How?
You cannot stick to a program long enough if you do not enjoy it. To do any exercise, you must have fun in doing it. Fun makes it easier. Happiness is the second factor that makes life better and easy.
First, step to lose weight easily
Do not check your weight every day. Put aside your weighing machine and for some days forget about your weight. Make a picture of your slim body and hang it somewhere you can see it night and morning. Forget about losing weight or exercise or any other health issue.
Second step
Exercise is important so let us do it. In the beginning, do not put stress on yourself. We do not want to do cardiovascular exercise on our first day. Stand still and start dancing on the rhythm of music. Move your right arm up and then move it down. Do it a few times. Do exercise slightly and without effort. Try to have fun during your exercise time.
Third step
Start with MS excel. In your spreadsheet write your goals and list them. Your first goal should be to drink 8 glasses of water daily. Second goal can be to walk for 20 minutes daily. Third goal can be to dance for 15 minutes. In this way, you can fill the entire table. Now go behind your goals. When you have done drinking 8 glass of water, cut down the first column in your spreadsheet. In this way, you can reach to the end of your table where you will be slim and smart.
These steps will give you freedom and relief.
If you do not like exercise, look for some alternatives. You can play a game. You can join a gym or slimming center. You can do yoga. Yoga is fun for most people and yoga burns 3 calories per minute. Joining a gym is also a good option for many people.
Forget about dieting. Think about having a healthy meal.We are not looking to starve ourselves. It is about a healthy lifestyle. Make a variable diet plan and enjoy your healthy meals.
Best of luck!
用"When it comes to weight loss discussion there is always effort involved" 在google.com/ncr中查了一下,找到10篇类似的
还行,就看怎么使用这个文章了
发表于 2014-11-28 11:23:48 | 显示全部楼层
是不是有IP限制啊 怎么测试了一些次以后 打开就是空白了
发表于 2014-11-28 11:40:51 | 显示全部楼层
+1 也是空白的,貌似爆表了。
发表于 2014-11-28 11:55:51 | 显示全部楼层
1321 发表于 2014-11-28 11:40
+1 也是空白的,貌似爆表了。
IP又被封了。。。
发表于 2014-11-28 12:00:52 | 显示全部楼层
求乐锅如何采集EZ的?如果突破限制?
发表于 2014-11-28 14:19:48 | 显示全部楼层
好强大,请问乐版主,能够采集中文内容吗
 楼主| 发表于 2014-11-28 14:22:04 | 显示全部楼层
风吹不动 发表于 2014-11-28 12:00
求乐锅如何采集EZ的?如果突破限制?
曲线救国
 楼主| 发表于 2014-11-28 14:22:34 | 显示全部楼层
songsong123 发表于 2014-11-28 14:19
好强大,请问乐版主,能够采集中文内容吗
中文没有这种站 有的话可以的
发表于 2014-12-15 08:12:09 | 显示全部楼层
今天打开咋404了,不搞了吗
GMT+8, 2025-4-19 16:17
