查看: 904|回复: 2
godaddy whois 修改问题
发表于 2014-12-11 11:40:26 | 显示全部楼层 |阅读模式
Thank you for your email. Passports do not contain addresses. please provide a certified translation of the documentation that matches the updated address listed. Examples of acceptable documentation may include but is not limited to: Utility bill, rental agreement, or a government-issued photo ID.
Once this is received we will inform you if the claim has been closed or if we need additional information.
一个域名因为whois信息不正确被godaddy停用了,然后就让我提供带地址的证明文件,来来回回把身份证,护照都发给了客服,结果还是不行,有没有遇到过类似情况的,知道要怎么整
发表于 2014-12-11 12:52:22 | 显示全部楼层
你是做了什么触发了godaddy的审查?
一般情况下godaddy不会做这样事.
 楼主| 发表于 2014-12-11 13:24:23 | 显示全部楼层
电话格式不对,这很小事,狗爹不会因为这个停用域名  发表于 2014-12-11 16:42
你做了什么坏事? 或被别人举报了,如果域名不重要,果断放弃  发表于 2014-12-11 16:40
+1xxxxxxxxx 美国 +86xxxxxxxxx 中国  发表于 2014-12-11 16:36
GMT+8, 2025-4-12 23:09
