查看: 1008|回复: 3
域名还有 7天过期,应该从godaddy转入namesilo再续费吗
发表于 2014-12-21 20:33:30 | 显示全部楼层 |阅读模式
我很多年前注册了paypal,认证了,但是从来没有用过。
现在godaddy域名过期,一个要$14.99/yr,看到namesilo有免费隐私保护,所以想转过去。
1.如果域名快过期也可以转移过去吗?
2.转移过去就必须立即续费吗?
发表于 2014-12-21 21:22:25 | 显示全部楼层
只要没过期就肯定可以转,转的时候需要付费的。
现在我已经转过去了,但是namesilo那边一直提示这个:Pending at Registry  发表于 2014-12-21 21:25
 楼主| 发表于 2014-12-21 21:25:09 | 显示全部楼层
现在这样了,namesilo这边提示Pending at Registry 。我在godaddy那边已经accept transfer了。但是namesilo这边还是这样的提示:Pending at Registry,而且我用paypal绑定招行全币种,但是却被额外扣了1美元。我看到网上说这是预扣,貌似可以返还,那是要多久才返还?
Pending at Registry
Your transfer request is pending at the central registry. The registrar you are transferring away from has 5 days to cancel the request, or else it will proceed. Some registrars allow expediting outbound transfers by manually approving the transfer request from within your account. You may try logging into your account at the registrar you are leaving, or asking them if this is an option for you.Your current registrar has until 2014-12-26 06:15:27 to reject the transfer.If they do not reject the transfer, it will complete within 48 hours of this date and time.There is unfortunately nothing we can do to expedite this process. You can read moreconcerning the timing of transfer completions by clicking the Help icon on the top of this page.
发表于 2014-12-22 11:50:01 | 显示全部楼层
转入的时候系统默认是要续费1年的,不续费无法转入。
还有7天过期可以转入,GD转NS只要一个小时以内,很快的。
谢谢了,我昨天晚上花了1个小时搞定了  发表于 2014-12-22 11:51
GMT+8, 2025-4-12 21:43
