查看: 4059|回复: 66
又被amazon封了一个账户,但没提供具体违规条款
发表于 2015-1-31 07:36:52 | 显示全部楼层 |阅读模式
[mw_shl_code=applescript,true]You can find the complete terms of the Operating Agreement and its Schedules via this link:  https://affiliate-program.amazon.com/gp/associates/agreement.[/mw_shl_code]
发表于 2015-1-31 09:14:13 | 显示全部楼层
哎,可惜了
发表于 2015-1-31 10:03:39 | 显示全部楼层
有违规的地方吧,发下邮件全文瞅瞅
发表于 2015-1-31 10:05:06 | 显示全部楼层
转化率这么高?是有很大风险
 楼主| 发表于 2015-1-31 10:09:26 | 显示全部楼层
We are writing to notify you that we are terminating the Amazon Associates Program Operating Agreement with you with immediate effect.  Your Associates Program account will be closed and you will not receive further payment of advertising fees.  We have taken this step because you are not in compliance with the Operating Agreement that governs your participation in the Associates Program.
We insist that you immediately remove all Amazon content, including Special Links, from your site(s).  Any other accounts you have or may open in the future may be closed and you will not receive any advertising fees.  We reserve all other rights and claims we may have.
 楼主| 发表于 2015-1-31 10:16:31 | 显示全部楼层
发表于 2015-1-31 10:16:43 | 显示全部楼层
风吹不动 发表于 2015-1-31 10:09
We are writing to notify you that we are terminating the Amazon Associates Program Operating Agreeme ...
确实看不出违规的原因,你感觉有违规吗,转化率是有点高,或者网站质量怎么样?采集还是niche就几篇文章的站?
发表于 2015-1-31 10:17:35 | 显示全部楼层
这种感觉可能和网站质量关系比较大,上次被封是什么时候,有没有换站操作,也有可能被关联
发表于 2015-1-31 10:28:30 | 显示全部楼层
确认没有作弊和违规就写信申述试试吧
 楼主| 发表于 2015-1-31 10:29:19 | 显示全部楼层
ufo889 发表于 2015-1-31 10:16
确实看不出违规的原因,你感觉有违规吗,转化率是有点高,或者网站质量怎么样?采集还是niche就几篇文章 ...
如果知道哪里违规就不用问了
wordpress + woocommerce + api,添加到购物车后到amazon结算,所以这转换率不算高
为了防止违规连价格、评论都没调用
 楼主| 发表于 2015-1-31 10:30:19 | 显示全部楼层
ufo889 发表于 2015-1-31 10:28
确认没有作弊和违规就写信申述试试吧
求申诉模板
发表于 2015-1-31 10:32:21 | 显示全部楼层
转化率这么高不像是采集站,如果是NICHE站那就太不讲道理了
 楼主| 发表于 2015-1-31 10:35:03 | 显示全部楼层
api站,如果你知道网站的流量就不会觉得转换率高了
发表于 2015-1-31 10:36:37 | 显示全部楼层
12% 已经很高了,上次被封申请时注意换电脑,IP,个人资料啊,网站域名也要换,不能301,还有我个人感觉Amazon 可能比较反感这种模式。 就发信说你认真做站没有违反政策啊,让他们说明违反了哪一个政策。
 楼主| 发表于 2015-1-31 10:47:37 | 显示全部楼层
ufo889 发表于 2015-1-31 10:36
12% 已经很高了,上次被封申请时注意换电脑,IP,个人资料啊,网站域名也要换,不能301,还有我个人感觉Ama ...
貌似现在申请号很容易过,关键是还有几个号也是同样的模式的站,如果不搞明白另外的号也危险
发表于 2015-1-31 10:51:43 | 显示全部楼层
这个号搞多久被封的,如果收益大于投入很多,冒着被封的风险也可以搞啊,其他如果佣金比这个还高没被封,可能就不怪这个模式
发表于 2015-1-31 10:57:37 | 显示全部楼层
呵呵,现在封号很恐怖啊,采集站,api站,全部被封
发表于 2015-1-31 11:01:10 | 显示全部楼层
我也感觉是,网站质量差的就算没有违规都有可能被封的危险,但API站不了解,API不是Amazon官方提供的吗,为什么也封?
 楼主| 发表于 2015-1-31 11:05:47 | 显示全部楼层
ufo889 发表于 2015-1-31 10:51
这个号搞多久被封的,如果收益大于投入很多,冒着被封的风险也可以搞啊,其他如果佣金比这个还高没被封,可 ...
产出比很高,只是无法判断是否是模式问题
发表于 2015-1-31 11:06:58 来自手机 | 显示全部楼层
前几天也被封了号,到现在都不知道是什么原因,放着什么都没做就违规了,还好收入不多。果断放弃amazon。
GMT+8, 2025-4-12 23:18
