查看: 894|回复: 6
cj又支持中国了!!!
发表于 2005-3-17 01:32:57 | 显示全部楼层 |阅读模式
: 香港也是中国的一部分
这里比较冷清 灌点水
 楼主| 发表于 2005-3-17 02:29:23 | 显示全部楼层
CarPrices.com: Your application has been declined by this advertiser for one or more reasons. If you have a question please contact the advertiser through advertisers detail page within the account manager.
ADVFN: This advertiser approves publishers manually. Your application status will be set to "Pending Application" and the advertiser will contact you if approved.
Reply.com: This advertiser approves publishers manually. Your application status will be set to "Pending Application" and the advertiser will contact you if approved.
Cooking.com: This advertiser approves publishers manually. Your application status will be set to "Pending Application" and the advertiser will contact you if approved.
Rentalo: Congratulations. Your application has been approved and you are now a member of the advertisers program.
Citibank Deutschland: Your application has been declined by this advertiser for one or more reasons. If you have a question please contact the advertiser through advertisers detail page within the account manager.
eWatches.com: Congratulations. Your application has been approved and you are now a member of the advertisers program.
ValueClick Media: This advertiser approves publishers manually. Your application status will be set to "Pending Application" and the advertiser will contact you if approved.
发表于 2005-3-17 14:45:19 | 显示全部楼层
靠,有香港没中国。
发表于 2005-3-17 15:58:33 | 显示全部楼层
晕~还以为是真的
发表于 2005-3-18 09:29:04 | 显示全部楼层
靠 扔易拉罐 :
发表于 2005-3-18 14:15:09 | 显示全部楼层
不要这样吗,伤心
michaelzp 该用户已被删除
发表于 2005-3-20 00:54:49 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2025-4-20 04:39
