查看: 2266|回复: 18
老子头都大了 最近准备买几个好点的域名
发表于 2006-6-12 05:51:16 | 显示全部楼层 |阅读模式
可能给大家开放BLOG 正在与股东商量 我正在找域名 但是一直找不到好的
简单的 好记的就可以了 但是全部都被注册完了
 楼主| 发表于 2006-6-12 06:27:05 | 显示全部楼层
好998.com   这个怎么样啊
 楼主| 发表于 2006-6-12 06:32:25 | 显示全部楼层
受不了 睡觉先 老子眼睛都看麻了
发表于 2006-6-12 07:10:17 | 显示全部楼层
跟!
发表于 2006-6-12 09:28:54 | 显示全部楼层
ioiyou.com
发表于 2006-6-12 12:06:25 | 显示全部楼层
静水给大家的开放博客.com
这个不挺好记么?
发表于 2006-6-12 12:22:10 | 显示全部楼层
888blogs.com 此域名可以注册
888blogs.net 此域名可以注册
888blogs.org 此域名可以注册
888blogs.biz 此域名可以注册
888blogs.info 此域名可以注册
888blogs.cn 此域名可以注册
发表于 2006-6-12 13:54:04 | 显示全部楼层
原帖由 iamphp 于 2006-6-12 07:10 发表
跟!
典型的灌水型马后炮。
发表于 2006-6-12 14:28:16 | 显示全部楼层
一个字母加3个数字,这种的能申的多了
发表于 2006-6-12 14:28:34 | 显示全部楼层
www.popcoke.com 刚过期几天
发表于 2006-6-12 14:35:39 | 显示全部楼层
popcoke.com的详细信息:
Whois Server Version 2.0
Domain names in the .com and .net domains can now be registered
with many different competing registrars. Go to http://www.internic.net
for detailed information.
   Domain Name: POPCOKE.COM
   Registrar: ENOM, INC.
   Whois Server: whois.enom.com
   Referral URL: http://www.enom.com
   Name Server: DNS1.NAME-SERVICES.COM
   Name Server: DNS4.NAME-SERVICES.COM
   Name Server: DNS5.NAME-SERVICES.COM
   Name Server: DNS2.NAME-SERVICES.COM
   Name Server: DNS3.NAME-SERVICES.COM
   Status: REGISTRAR-LOCK
   EPP Status: clientDeleteProhibited
   EPP Status: clientTransferProhibited
   EPP Status: clientUpdateProhibited
   Updated Date: 10-Jun-2006
   Creation Date: 10-Jun-2005
   Expiration Date: 10-Jun-2007
>>> Last update of whois database: Mon, 12 Jun 2006 02:31:53 EDT <<<
NOTICE: The expiration date displayed in this record is the date the
registrar's sponsorship of the domain name registration in the registry is
currently set to expire. This date does not necessarily reflect the expiration
date of the domain name registrant's agreement with the sponsoring
registrar.  Users may consult the sponsoring registrar's Whois database to
view the registrar's reported date of expiration for this registration.
TERMS OF USE: You are not authorized to access or query our Whois
database through the use of electronic processes that are high-volume and
automated except as reasonably necessary to register domain names or
modify existing registrations; the Data in VeriSign Global Registry
Services' ("VeriSign") Whois database is provided by VeriSign for
information purposes only, and to assist persons in obtaining information
about or related to a domain name registration record. VeriSign does not
guarantee its accuracy. By submitting a Whois query, you agree to abide
by the following terms of use: You agree that you may use this Data only
for lawful purposes and that under no circumstances will you use this Data
to: (1) allow, enable, or otherwise support the transmission of mass
unsolicited, commercial advertising or solicitations via e-mail, telephone,
or facsimile; or (2) enable high volume, automated, electronic processes
that apply to VeriSign (or its computer systems). The compilation,
repackaging, dissemination or other use of this Data is expressly
prohibited without the prior written consent of VeriSign. You agree not to
use electronic processes that are automated and high-volume to access or
query the Whois database except as reasonably necessary to register
domain names or modify existing registrations. VeriSign reserves the right
to restrict your access to the Whois database in its sole discretion to ensure
operational stability.  VeriSign may restrict or terminate your access to the
Whois database for failure to abide by these terms of use. VeriSign
reserves the right to modify these terms at any time.
The Registry database contains ONLY .COM, .NET, .EDU domains and
Registrars.
[whois.enom.com]
Registration Service Provided By: Gold-Domain, Inc.
Contact: support @ gold-domain . com
Visit: http://www.gold-domain.com
Domain name: popcoke.com
Registrant Contact:
   Chris Day ([email protected])
   +1.5053543261
   Fax: +1.11
   2479 Main St
   Santa Fe, NM 87501
   US
Administrative Contact:
   +1.5053543261
   Fax: +1.11
   2479 Main St
   Santa Fe, NM 87501
   US
Technical Contact:
   +1.5053543261
   Fax: +1.11
   2479 Main St
   Santa Fe, NM 87501
   US
Status: Locked
Name Servers:
   dns1.name-services.com
   dns2.name-services.com
   dns3.name-services.com
   dns4.name-services.com
   dns5.name-services.com
Creation date: 10 Jun 2005 05:46:11
Expiration date: 10 Jun 2006 05:46:11
Whois-Services: [email protected]
The data in this whois database is provided to you for information
purposes only, that is, to assist you in obtaining information about or
related to a domain name registration record. We make this information
available "as is," and do not guarantee its accuracy. By submitting a
whois query, you agree that you will use this data only for lawful
purposes and that, under no circumstances will you use this data to: (1)
enable high volume, automated, electronic processes that stress or load
this whois database system providing you this information; or (2) allow,
enable, or otherwise support the transmission of mass unsolicited,
commercial advertising or solicitations via direct mail, electronic
mail, or by telephone.  The compilation, repackaging, dissemination or
other use of this data is expressly prohibited without prior written
consent from us.  The registrar of record is eNom.  We reserve the right
to modify these terms at any time. By submitting this query, you agree
to abide by these terms.
Version 6.3 4/3/2002
[HiChina Format]
Domain Name ..................... popcoke.com
Registrant Name ................. Chris Day
Registrant Organization .........
Registrant Address .............. 2479 Main St
                                  Santa Fe, NM 87501
                                  US
Registrant City ................. Santa Fe
Registrant Province/State ....... NM
Registrant Postal Code .......... 87501
Registrant Country Code ......... US
Registrant Phone Number ......... +1.5053543261
Registrant Fax .................. +1.11
Registrant Email ................ [email protected]
Administrative Name ............. Chris Day
Administrative Organization .....
Administrative Address .......... 2479 Main St
                                  Santa Fe, NM 87501
                                  US
Administrative City ............. Santa Fe
Administrative Province/State ... NM
Administrative Postal Code ...... 87501
Administrative Country Code ..... US
Administrative Phone Number ..... +1.5053543261
Administrative Fax .............. +1.11
Administrative Email ............ [email protected]
Technical Name .................. Chris Day
Technical Organization ..........
Technical Address ............... 2479 Main St
                                  Santa Fe, NM 87501
                                  US
Technical City .................. Santa Fe
Technical Province/State ........ NM
Technical Postal Code ........... 87501
Technical Country Code .......... US
Technical Phone Number .......... +1.5053543261
Technical Fax ................... +1.11
Technical Email ................. [email protected]
 楼主| 发表于 2006-6-12 14:42:14 | 显示全部楼层
原帖由 iamphp 于 2006-6-12 14:35 发表
popcoke.com的详细信息:
fo ...
天才克庸才,野人克一切
发表于 2006-6-12 14:44:59 | 显示全部楼层
发表于 2006-6-12 14:48:59 | 显示全部楼层
暗语!!!
发表于 2006-6-12 16:01:57 | 显示全部楼层
呵呵,不明白中
发表于 2006-6-12 23:13:52 | 显示全部楼层
if99.com
我的要出售
 楼主| 发表于 2006-6-12 23:24:02 | 显示全部楼层
原帖由 qlljh 于 2006-6-12 23:13 发表
我的要出售
这个不好 我昨天看见了的
发表于 2006-6-12 23:24:28 | 显示全部楼层
多少钱呢?
发表于 2006-6-12 23:46:32 | 显示全部楼层
www.veryblog.com
非常博客
4 sale
GMT+8, 2025-4-17 21:12
