查看: 649|回复: 0
Moveable Type Backlink Exploit
发表于 2006-7-22 16:22:25 | 显示全部楼层 |阅读模式
Do you want free backlinks? Does the Pope shit in the woods?
Boogybonbon has found a way to exploit the preview comment form to create backlinks from Movable type blogs.
From the post, MovableType preview button good for back links:
As long as the blog is not a MovableType 3.2/3.x the blog will give a nice URL that you can publish into a ping list and get indexed for back links. This is because the MovableType 3.x uses JavaScript to convert tags into a preview comment field and as we all know search engines cant see that.
Needles to say it only took me about 15 minutes to find 6 blogs with PR 5-8 and process the forms over to GET then post the URL’s into a couple ping sites.
Here’s how it works:
The preview comment button on movable type blogs uses the POST method but search engines require the GET method to index a URL. So, what you need to do is:
1. Download the firefox extension webmaster tools to convert the POST forms to GET forms.
2. Find Movable type blogs.
3. Open The “preview Comment” in a new window.
4. Convert the POST Form to a GET Form like this:
5. Fill out comment however you like.
6. Press preview comment.
7. Instead of producing a url like this:
http://www.baseballmusings.com/cgi-bin/mt/mt-comments-pinto.cgi
it will produce a URL like this (images used for formating purposes):
The links on the produced pages are NOT nofollow.
8. Now, you may want to use a service like tinyurl or a redirect to hide what you are doing (not required)
9. Ping that URL to the Search Engines in splog posts, guestbooks, or however you think best.
Pretty freaking cool, huh?
[ 本帖最后由 teru1987 于 2006-7-22 16:23 编辑 ]
GMT+8, 2025-4-4 15:07
