查看: 1777|回复: 0
Chitika Release WordPress Plugin v2.0
发表于 2006-7-29 12:38:56 | 显示全部楼层 |阅读模式
This plugin allows you to put a Chitika eMiniMall right into the body of the blog post. There is also a convenient button in the editor to customize keywords, colors etc.
Whats New:
The plugin configuration is now done through the Wordpress options tab. No need to edit the files.
To put a eMiniMall right into your blog post, there is now a little button on the editor to help you add and customize the eMiniMal l for that particular post
This plugin is backward compatible with Wordpress 1.5. So you can use it with Wordpress 1.5 as well.
Download it here
GMT+8, 2025-4-29 08:49
