查看: 1521|回复: 1
最新版本的Subdreamer.CMS.Pro.v 2.3.5.PHP.NULL-SCRiPTMAFiA 提供下载!
发表于 2006-8-24 00:04:47 | 显示全部楼层 |阅读模式
最新版本的Subdreamer.CMS.Pro.v 2.3.5.PHP.NULL-SCRiPTMAFiA 提供下载!大家记得顶下噢!
Ы ЯЯ ЯЯЬЬЯЫЫЯ
Ы Subdreamer is a powerful yet simple program used for ЫЫЫЫ
Ы creating websites. With it's quick installation and easy ЯЯ
Ы to use admin interface you will have your website up and Ь
Ы running within minutes. Ы
Ы Whether your goal is creating a simple website with a Ы
Ы couple pages or a larger website with hundreds of pages, Ы
Ы Subdreamer will get you there by providing unbeatable Ы
Ы content management tools. Ы
Ы Thumbnail fix included. Ы
Ы Ы
Ы NOTE: Today we also present our own developed PHP-based Ы
Ы release checker which will be included in all script Ы
Ы releases we do in the future. We did this step to prevent Ы
Ы against fake releases and people who try to claim our work Ы
Ы as their own and even distribute it like that. Ы
Ы In addition we don't add visible watermarks anymore, to Ы
Ы secure the script against all the anti-piracy agencies Ы
Ы which are around and trying to rip you off. Ы
Ы Ы
Ы RELEASE CHECKER NOTES: Ы
Ы It works just like a sfv checker but is using the more Ы
Ы sensitive MD5 sums and as it's PHP-based it needs the same Ы
Ы requirements like the script: a webserver running PHP. Ы
Ы Do not try to edit, rename or delete any file else the Ы
Ы release checker will give you errors and you definitely Ы
Ы got a modified release - in that case make sure you read Ы
Ы our reminder below. Ы
Ы We recommend you to remove sm-check.php and sm-check.md5 Ы
Ы after the validation if you want to run it in public. Ы
Ы The source code is protected using a custom base64 Ы
Ы encoding which increased the file size so don't waste your Ы
Ы time on that, just use it and enjoy our releases. Ы
Ы Expect more ... Ы
cfan0330 该用户已被删除
发表于 2006-8-24 11:08:55 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2025-4-16 18:42
