查看: 784|回复: 4
芭比 393相对于392来说有哪些改进的地方?
发表于 2006-8-29 14:15:14 | 显示全部楼层 |阅读模式
哪位朋友知道的?
发表于 2006-8-29 14:22:57 | 显示全部楼层
Clicking Agent v3.93
Accounts list
Added traffic counter of downloaded headers and web pages content. This lets control traffic usage by different accounts;
Account settings
Stay within domain option in Account Analyze Clicks and Analyze Shows settings lets you avoid unnecessary traffic and speeds up account processing. Clicking Agent downloads content only from the domain which is the source of the banner;
Stop URL parameter in account analyze settings helps you avoid unnecessary traffic and speeds up account processing. When this option is enabled other page past this URL will not be downloaded and analyzed. This helps to reduce traffic usage and adds another convenient condition to stop clicking.;
Proxy list
Added Update now button to the proxy list options dialog which lets updating proxies without having to wait for scheduled time;
Proxy list can be updated from LoteSoft's proxy list subscription;
Other
Added substitutioin of <SELECT> parameter with a predefined value when using Form rules;
Added direct processing of XML pages returned by some search engines;
Added processing of "scripted" links, that is <A ...> tags containing JavaScript code as a value of their HREF or OnClick parameter. This requires Process scripts option to be enabled;
Not completely downloaded web pages are not considrered an error any more. This helps to cope with some misconfigured web servers which don't close connection after transmitting the page;
Bug fixes
Fixed incorrect processing of <SELECT> and <OPTION> tags in forms where <OPTION> terminates with closing tag </OPTION>;
Relative links assigned to window.location etc. in JavaScripts are processed incorrectly;
ACCESS VIOLATION error when processing some of Java scripts;
Proxies are unchecked after error even if After how many errors... option is set to 0 in the Proxy List Options dialog;
Proxy list update sometimes causes the program to stop responding;
Erroneous Unregistered version message and program shutdown;
发表于 2006-8-29 15:54:56 | 显示全部楼层
到现在还不会用Form rules的人路过。^_^
发表于 2006-8-29 15:55:14 | 显示全部楼层
看的不太懂。如果不用翻译软件的话,就有点晕了。
发表于 2006-8-30 04:36:40 | 显示全部楼层
原帖由 zhuanqianhao 于 2006-8-29 15:55 发表
雷同
GMT+8, 2025-4-5 00:05
