查看: 2770|回复: 14
求人翻译如下东西 要地道的中文 不要机器翻译的 我要吐血了
发表于 2006-9-30 04:35:26 | 显示全部楼层 |阅读模式
1000e币
6. For a foreign government:
a.  I certify that the entity identified in Part I is a foreign government within the meaning of section 892 and the payments are within the scope of the exemption granted by section 892
b.  The entity identified in Part I is an integral part of the government:
c.  The entity identified in Part I is a controlled entity of the government.
7. For an international organization:
I certify that:
  • The entity identified in Part I is an international organization within the meaning of section 7701(a)(18) and
  • The payments are within the scope of the exemption granted by section 892.
8. For a foreign central bank of issue (not wholly owned by the foreign sovereign):
I certify that:
  • The entity identified in Part I is a foreign central bank of issue.
  • The entity identified in Part I does not hold obligations or bank deposits to which this form relates for use in connection with the conduct of a commercial banking function or other commercial activity, and
  • The payments are within the scope of the exemption granted by section 895.
9. For a foreign tax-exempt organization, including foreign private foundations:
If any of the income to which this certification relates constitutes income includible under section 512 in computing the entity's unrelated business taxable income, send a statement identifying amounts.
a. I certify that the entity identified in Part I has been issued a determination letter by the IRS dated  that is currently in effect and that concludes that it is an exempt organization described in section 501(c).
For section 501(c)(3) organizations only, check appropriate:
b. If the determination letter or opinion of counsel concludes that the entity in Part I is described in section 501(c)(3), I certify that the organization is not a private foundation described in section 509. I will send an affidavit of the organization setting forth sufficient fact for the IRS to determine that the organization is not a private foundation because it meets one of the exceptions described in section 509(a)(1), (2), (3), or (4)
c. If the determination letter or opinion of counsel concludes that the entity identified in Part I is described in section 501(c)(3), I certify that the organization is a private foundation described in section 509.
10. For a government of a U.S. possession:
I certify that the entity identified in Part I is a government of a possession of the United States, or is a political subdivision thereof, and is claiming the exemption granted by section 115(2).
发表于 2006-9-30 09:34:10 | 显示全部楼层
: : : 看懂了。。。不帮你翻~~~
发表于 2006-9-30 09:36:21 | 显示全部楼层
原帖由 狐狸宝宝 于 2006-9-30 09:34 发表
: : : 看懂了。。。不帮你翻~~~
发表于 2006-9-30 09:46:40 | 显示全部楼层
静水应该是能看懂的,诈唬别人的
发表于 2006-9-30 09:54:41 | 显示全部楼层
这段文字似乎在哪里见过好多回
发表于 2006-9-30 09:56:14 | 显示全部楼层
: : : 看懂了。。。不帮你翻~~~
哈哈,宝宝的经典幽默!!!:
发表于 2006-9-30 09:58:03 | 显示全部楼层
原帖由 hahafei 于 2006-9-30 09:54 发表
这段文字似乎在哪里见过好多回
用非美地址申请就出来这个了
 楼主| 发表于 2006-9-30 10:00:30 | 显示全部楼层
不是W8BEN 是W8另外一个表 所以我看昏了撒
发表于 2006-9-30 18:24:05 | 显示全部楼层
回家帮你看看。。。 :
发表于 2006-9-30 19:37:12 | 显示全部楼层
我肯定看不懂的。
kyxt 该用户已被删除
发表于 2006-10-1 15:40:29 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
kyxt 该用户已被删除
发表于 2006-10-1 15:41:25 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2006-10-1 22:38:47 | 显示全部楼层
w8 xp
tonghua 该用户已被删除
发表于 2006-10-2 14:44:25 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2006-10-3 13:43:52 | 显示全部楼层
乱填,还签了名会不会收不到票啊?5555~~~
GMT+8, 2025-4-19 19:33
