查看: 1490|回复: 0
CJ的回信
发表于 2006-12-14 09:32:35 | 显示全部楼层 |阅读模式
Good Morning.
Thank you for contacting Commission Junction. Commission Junction issues checks for previous month???s commissions around the 20th of the month when your account meets or exceeds Commission Junction???s ???Minimum Balance Amount.???
We combine commission payments from all advertiser partners that each publisher is working with. There is a $25.00 minimum withdrawal unless the publisher chooses a higher minimum payout amount. (Publishers that request payment in a currency other than U.S. dollars must reach a minimum equivalent to $50.00 U.S. dollars.) If a publisher???s account balance is less than $25.00 at the end of the month, we roll over the commissions into the following month.
When you click on the ???Run Reports??? tab it opens a summary of your current balance and pending commissions.
???New??? Pending Commissions are recent transactions that have generated a commission, but they have yet to be reviewed and approved by the advertiser. In order to protect the advertiser from possible fraud, order cancellations or returns, the advertiser has the opportunity to review transactions to make sure they are valid.
???Extended??? means that the advertiser has requested another 30 days in which to make a decision ??“ advertisers may do this once for each transaction. Commissions that are not extended or corrected are ???Locked??? on the 10th of each month. ???Locked??? commissions will, more than likely, roll into the commission balance that will be paid out on or around the 20th of each month. Once a payment has been processed the ???Balance??? is reduced accordingly.
We hope this answers your question. If you have further questions, please don???t hesitate to contact us.
Sincerely,
Commission Junction Client Support
GMT+8, 2025-4-15 16:48
