查看: 1489|回复: 2
谁可以帮我写封英文信,只要一点点就够啦
发表于 2007-3-26 03:27:20 | 显示全部楼层 |阅读模式
先谢谢啦,写到加拿大的
以下是信笺内容:
你好
我的正确地址与姓名是:***
中文正确的地址与姓名是:***
最好可以按中文的地址与姓名打印到信封帮我寄过来,这样就绝对能寄的到拉
谢谢!!
发表于 2007-3-26 09:01:51 | 显示全部楼层
Hi,
My correct address is:
My correct name is:
My correct Chinese address is:
My correct Chinese name is:
I hope you can print my chinese name and address on the envelopment,i'm sure i can get it in that way.
thanks,
regards
参与人数 1 +5 收起 理由
段续风 + 5 乐于助人
发表于 2007-3-26 09:05:28 | 显示全部楼层
Dear Sir:
My correct name and address is :XXXXX
My correct Chinese names and addresses are  :XXXX
Chinese names and addresses can be the best print envelopes to send me up, it would absolutely be able to send for me
Thank you very much!
参与人数 1 +5 收起 理由
段续风 + 5 乐于助人
GMT+8, 2025-4-15 16:48
