查看: 2073|回复: 4
求救:CJ给我来信了,哪位朋友帮我写封申辩信
发表于 2007-3-26 18:17:36 | 显示全部楼层 |阅读模式
CJ给我来信了,好像是说我有欺骗点击,内容如下。哪位朋友帮我写封申辩信,请问高手们,如果我写信申辩有用吗?申辩信该怎么写?先谢谢能帮忙的朋友了。
Dear ****,
In accordance with Commission Junction’s Publisher Service Agreement, (http://www.cj.com/psa.html ), you are being warned for violating the Publisher Service Agreement, including inflating traffic (forcing clicks) to one or more of your affiliated advertisers.  Clicks and Transactions are only considered valid when generated by an affirmative-action by the End-User/Visitor.  You may not generate clicks or transactions for the advertisers you are affiliated with unless you have documented authorization from the advertiser. As a result, your account is under payout review.
You must remove any and all mechanisms that inflate traffic or force clicks within 48 hours of receipt of this warning notice.  Failure to do so may result in the termination of your Commission Junction Publisher account and the charge-back (reversal) of commissions by the appropriate advertisers.
If you have any questions, please reply to this message.  If you are reading this notice through your CJ Account Manager (Mail tab) and do not have access to the e-mail notice, please respond using Ask a Question, available through the “Contact Us” link available in account manager, and include this original message.
Sincerely,
Network Quality
Commission Junction, a ValueClick company
You have received this e-mail because you are a member of the Commission Junction network.  As a member, you will periodically receive messages from Commission Junction that you are unable to unsubscribe from because they contain important account or network information.  You may contact Commission Junction by logging into your CJ Account Manager and selecting the “Contact Us” link.
CONFIDENTIAL AND PROPRIETARY INFORMATION OF COMMISSION JUNCTION. (C) 2006 Commission Junction, Inc. All rights reserved. This work contains information that is confidential and proprietary information to Commission Junction. Removal of this notice, and use, examination, disclosure, transfer and copying of all or part of this work are prohibited, except with the express written consent of Commission Junction.
If you need further assistance to this issue or to answer an inquiry, please use the "reply-to" address.
发表于 2007-3-27 10:05:15 | 显示全部楼层
: 死了心吧  CJ历史上还没有申辩成功的记录
 楼主| 发表于 2007-3-27 10:40:11 | 显示全部楼层
是你?道莲??回答我的问题!谢谢,承蒙指教。好的,死心了,看来国内的号是玩不了了,只有玩别的、找别的树去了。郁闷。
发表于 2007-3-27 11:51:07 | 显示全部楼层
是啊,不光是CJ,对中国帐号特别严
发表于 2007-3-27 16:21:33 | 显示全部楼层
原帖由 道莲 于 2007-3-27 10:05 发表
你能代表历史吗!!话不要说的那么绝对!!
GMT+8, 2025-4-17 21:07
