查看: 1431|回复: 2
请求翻译帮助-奖励论坛B
发表于 2007-5-12 17:18:44 | 显示全部楼层 |阅读模式
Dear***
I wanted to inform you that we were having a little bit of trouble with our tracking URL over the past few days.  However, everything is back in working order.  The reporting in your Commission Junction interface will most likely show that no leads have been generated for WealthMen.com from May 1st to May 10th.  Please be assured that transactions have gone through and we are working on gathering that information so our publishers will be paid.
We appreciate your patience while we remedy this problem.  Again the tracking issue has been solved and it is business as usual.  We will have all of the lead information gathered and calculated by the time commissions lock on the 10th of next month.  Please contact our Program Manager Eric Vanderwold if you have any questions.  Thanks again for all your hard work and thank you for being a part of the WealthyMen Affiliate Program.
Sincerely,
Abe Smilowitz
CEO
Wealthymen
Eric Vanderwold
Program Manager
发表于 2007-5-12 20:25:23 | 显示全部楼层
发这封信是为了通知下你,在过去的几天里,我们的网址出现了点小问题。不过现在一切已经回复正常了!
情况显示在5.1-5.10之间,通过WealthMen.com没有产生任何lead.请确认所有的交易都已经通过。我们正在整理数据,之后将支付给大家!
在处理网站问题的时候,谢谢您的耐心等待!我们下次清算lead的时间是在6.10号,如果有任何问题请与我们的工作人员ERIC联系!
参与人数 1 +5 收起 理由
段续风 + 5 乐于助人
 楼主| 发表于 2007-5-14 21:20:30 | 显示全部楼层
奖励20个B
虽然不多 以示鼓励
GMT+8, 2025-4-17 03:21
