查看: 1900|回复: 5
怎么更换PARKED风格
发表于 2007-6-22 13:58:12 | 显示全部楼层 |阅读模式
我比较喜欢竖排的,可是默认都是这样的
,我想换成
,怎么换?我在后台搞了半天没整出来,这两个是同一风格的不同版式,好象没找到对它们两个进行选择的按钮。不会不能选择吧,那他做出来不就没用拉?哪个大哥高人指点一下子
发表于 2007-6-22 14:40:31 | 显示全部楼层
图片挺诱惑人的
发表于 2007-6-22 15:56:59 | 显示全部楼层
貌似不能自由更换的,
嘿嘿。。。
 楼主| 发表于 2007-6-22 18:53:35 | 显示全部楼层
难道系统自动选择,可是我就没见我的停放页出现地二种风格的
发表于 2007-6-23 07:40:51 | 显示全部楼层
换不了的,第二张是直接出广告,跟你的米有关
发表于 2007-7-6 15:24:00 | 显示全部楼层
原帖由 sun 于 2007-6-22 18:53 发表
跟米有关。
1 Click Domain
Based on your domain name and the keywords that are in the domain our system determines if your domain should go directly to the results page or go to the landing page. If your domain goes directly to results this means that it is a 1 click domain. Because a surfer only has to click on one link for you to get paid.
2 Click Domain
Based on your domain name and the keywords that are in the domain our system determines if your domain should go directly to the results page or go to the landing page. In many cases your domain will go to the landing page. When a surfer goes to a landing page, they have to click twice before you make any money. This is why this type of domain is called a 2 click domain.
GMT+8, 2025-4-19 11:10
