查看: 2392|回复: 17
CJ发来封信,大家看看,如何回答!
发表于 2007-7-17 08:15:27 | 显示全部楼层 |阅读模式
Commission Junction is currently investigating your account and has the
following inquiries regarding your promotional methods:
Please describe again how you drive your traffic. The traffic does
suggest some kind of subaffiliate network or cashback or incentive.
Please respond by replying to this specific e-mail within five days of
delivery date.  If you are reading this notice through your CJ Account
Manager (Mail tab) and do not have access to the e-mail notice, please
respond using Ask a Question, available through the 鈥淐ontact Us鈥? lik available in account manager, and include this original message.
  Failure to respond may result in Commission Junction exercising its right
to terminate the Commission Junction Publisher Service Agreement upon
15 days of this written notice.
各位兄弟帮忙看看怎么回复比较好!
发表于 2007-7-17 12:53:57 | 显示全部楼层
回答的好,就问题不会很大,我收过类似的信,不要再为自己找麻烦就是
 楼主| 发表于 2007-7-17 13:43:16 | 显示全部楼层
怎么回答啊?
请高手指点下.急`~~~~~
发表于 2007-7-17 16:14:35 | 显示全部楼层
对你的流量有怀疑。
发表于 2007-7-17 16:57:06 | 显示全部楼层
同问???
同问???
 楼主| 发表于 2007-7-18 07:31:30 | 显示全部楼层
2楼的的兄弟是怎么回复的?请指点一下!
发表于 2007-7-18 15:26:13 | 显示全部楼层
学习下
发表于 2007-7-18 19:04:50 | 显示全部楼层
见识一下
 楼主| 发表于 2007-7-19 08:42:45 | 显示全部楼层
Recently you requested personal assistance from our on-line support center. Below is a summary of your request and our response.
Commission Junction will assume your issue has been resolved if we do not hear from you within 72 hours.
Thank you for allowing us to be of service to you. Client Services Commission Junction, A Valueclick Company
There is some discussion underway at this end as to whether or not Adbrite will continue to be allowed in our network. But, it may well turn out that it is allowed, but only if used with certain limitations. Given that, how do you use Adbrite? What kind of settings or scenarios do you use?
我回复了我在GG上面做了广告,上面是他们的最新回复,大家看看,高手指点下........急......
[ 本帖最后由 glqs 于 2007-7-19 08:44 编辑 ]
发表于 2007-7-19 09:06:44 | 显示全部楼层
原帖由 glqs 于 2007-7-19 08:42 发表
Commission Junction will assume your issue has been resolved i ...
我先问你你懂不懂怎么搞ADWORDS 他让你给个例子给他 你就差不多等于完蛋了
他们一般给个套子你钻,你说得越多,错得越多 估计你这个情况完蛋了 你还不如直接回答你用的动机流量 他就要求你把你的帐户类型改成动机 号一般绝对不得K的
 楼主| 发表于 2007-7-19 09:11:28 | 显示全部楼层
啊,老大,现在还有什么方法可以补救吗?
我昨天回复是这样的:
Hi,Administrators,how are you!
I have Advertise in the Adbrite and Google.
我的站最近流量不是很大,怎么也查我.郁闷,我有做Adbrite,
可以这样说吗,就说我几个月前在Adbrite做了广告,现在没做了,确实现在的流量没前几个月流量大.
求助.....老大 !
[ 本帖最后由 glqs 于 2007-7-19 09:22 编辑 ]
 楼主| 发表于 2007-7-20 08:11:34 | 显示全部楼层
看来我这个也没希望了`~~~晕``~~~
sadffg 该用户已被删除
发表于 2007-7-21 09:21:23 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
 楼主| 发表于 2007-7-24 08:27:29 | 显示全部楼层
大家看看......
Review of your account and its traffic indicates the use of promotional
method(s) in which Commission Junction, as detailed in the Publisher
Service Agreement, deems as special and requires an immediate update of
your account.
Adbrite
An accurate incentive/special program description is required to
operate in the CJ Marketplace.  Therefore, you must update your account by
going to the Account tab, Web site Settings and Incentive/Special
Program. Please verify that your account has been properly flagged as an
Incentive/Special Program by clicking on the edit box and marking the
鈥測es鈥?field.  Then provide an incentive/special program description in
the space provided.  Include as much detail as possible regarding your
program. If software is involved, include information regarding
distribution, branding, un-installation, and end user signup to services
provided by this software.  If you are using third party services and/or
publishing links on third party sites (sites that you do not own or
operate), provide a list of service providers and sites associated with such
provider.
If your account is already flagged as an Incentive/Special and an
updated description is required please reply to this e-mail and include as
much detail as possible regarding your program. If software is involved,
include information regarding distribution, branding, un-installation,
and end user signup to services provided by this software.  If you are
using third party services and/or publishing links on third party
sites (sites that you do not own or operate), provide a list of service
providers and sites associated with such provider. Once this information
is received Network Quality will update your account.
After this information is updated, all of your program鈥檚 advertiser
affiliations will be set to 鈥減ending鈥?and must first be re-approved
by individual advertiser(s) in order for tracking to resume.
Furthermore, your current or pending payout(s) are on hold until your
program gets updated correctly.  Realize that upon notice of special
program update, advertisers may choose to reverse unpaid transactions,
thus it is imperative that you provide a detailed and accurate
incentive/special program description.
大家看看......
[ 本帖最后由 glqs 于 2007-7-24 09:52 编辑 ]
发表于 2007-7-24 11:15:06 | 显示全部楼层
原帖由 glqs 于 2007-7-24 08:27 发表
Service Agreement, deems as special and requires an  ...
要你把你的帐户改成动机类型
然后你所有的广告的状态都会变成待审核状态
他们将重新审核你的情况是否予以投放你广告
当你做完帐户设置后 要再次告诉他们确认一次
 楼主| 发表于 2007-7-25 00:35:06 | 显示全部楼层
谢谢老大,马上就去搞搞.
 楼主| 发表于 2007-7-25 13:38:35 | 显示全部楼层
It needs to mention Adbrite specifically. I have turned off the flag so that you enter a proper description. What you put doesn't say much of anything ...
我应该如何回答???
 楼主| 发表于 2007-7-27 15:56:00 | 显示全部楼层
我应该如何回答???那位兄弟知道,请指点~~~
GMT+8, 2025-4-19 18:50
