查看: 1317|回复: 8
LS的付款周期是怎么样的,找了半天没有找到?
发表于 2007-8-12 16:26:32 | 显示全部楼层 |阅读模式
LS的付款周期是怎么样的,谁能具体说说,比如这个月做了,什么时候能发票?
 楼主| 发表于 2007-8-12 17:04:46 | 显示全部楼层
哪位大大,说说啊
发表于 2007-8-12 17:36:21 | 显示全部楼层
When will I receive my commission payment?
All merchants are now required to pay affiliates monthly. If LinkShare mails payment, LinkShare must first receive payment from the merchant to process checks before mailing payment. Thus, it may take 45-60 days after a specific month to receive payment. LinkShare will post the date checks are sent in the Payment Report on behalf of a merchant who chooses to have its checks mailed by LinkShare. LinkShare also posts a check number and provides the contact information used to mail the check.
If a merchant pays affiliates directly ("Check Mailed by - Merchant"), Merchants are required to input the date checks were mailed for any given month. You can find this date in the Payment Report section for each month. While LinkShare can't monitor this date, merchants are encouraged to report accurate information. If payment is not received soon after this date, you can report unpaid commissions by using the Non-Payment Alert Form.
Remember, in most cases, you will only be paid by the merchant if you've met the merchant's minimum threshold.
右上角:
   Help
参与人数 1 +5 收起 理由
yedelin + 5
发表于 2007-8-12 18:06:38 | 显示全部楼层
发表于 2007-8-12 18:28:23 | 显示全部楼层
LS这家公司出钱稍微有点慢。主要具体看你申请的什么公司了。有些公司是独立支付的,有些则是由LS来发票的,一般情况下,举例哈:1月产生的钱,一般情况下3月8号左右LS就会发票出来,每月发票时间在10号左右. LS有最低的支付标准。具体不一样,但一般是$25
OK?
参与人数 1 +5 收起 理由
yedelin + 5
 楼主| 发表于 2007-8-12 18:48:18 | 显示全部楼层
谢谢楼上几位。
发表于 2007-8-12 19:36:09 | 显示全部楼层
早改规则了 半个月支付一次 9号跟23号各支付一次 根据广告主资金到位情况支付 广告主如果资金到位快 这个月做的 次月9号就可以出票
发表于 2007-8-12 22:14:27 | 显示全部楼层
关键就看广告主了,他迟迟不付给LS,LS也就不给你啊。好多广告主也不守规矩的。
发表于 2007-8-13 11:00:54 | 显示全部楼层
LinkShare runs their payment batches on or around the 8th and 22nd each month. It may vary a few days either way, and it may take up to 3-5 business days from start to end. You never know for sure when it's going to start or end, but typically it's safe to say that they'll be in the mail or bank by the 14th and 28th.
Keep in mind that merchants typically pay LinkShare 30 (or more) days after the end of the month. Some (particularly Dell) pay more like 90+ days out. We don't get paid until the merchant pays LinkShare.
The first step, which we don't see, is the cutoff. All wire transfers received from merchants by the day before the cutoff will be included. All checks received and cleared from the merchants by the day before the cutoff will be included. LinkShare holds checks about a week to make sure they clear, so checks basically need to be received by around the 1st or 15th from merchants to be in the batch. Very few merchants use wire transfers, unfortunately, so this delay applies to most merchants.
Processing typically takes one or two business days after the cutoff. The payment usually appears in the Affiliate Payment Summary in Synergy Analytics during this time. The date doesn't usually correlate with the actual check or direct deposit.
Once processing is complete, the batch is sent to their bank and direct deposits and checks are usually sent within one or two business days.
So, basically, the first payment of the month should be in the bank or mail by about the 14th for all checks LinkShare received by the 1st. The second payment of the month should be in the bank or the mail by the 28th for all checks LinkShare received by the 15th. Not the most streamlined process, but that's how it is.
GMT+8, 2025-4-19 20:54
