查看: 2073|回复: 12
请教这封CJ来信的意思```
发表于 2007-8-23 09:00:23 | 显示全部楼层 |阅读模式
Dear *****
You have received this email because one or more of the advertisers you are affiliated with in the Commission Junction network has recently been temporarily deactivated.
The advertisers you are affiliated with that have been temporarily deactivated from the network are listed in the Deactivated Advertisers Report for your convenience. You are encouraged to check this Web page on a regular basis for the most up-to-date information. This list is available from the "Run Reports > Performance Reports" section of the account manager.
While an advertiser is in temporary deactivation status, publishers will not receive commissions from their banners, text links, and/or other links types. Please replace these links as soon as possible with links from active advertisers. A report of invalid links that are generating traffic but cannot earn revenue is available in the Invalid Links Generating Traffic Report. This report is also available under the "Frequently Run Reports" section of the "Run Reports > Performance Reports" tab. You will retain this affiliation if and when the advertiser reactivates their affiliate marketing program with Commission Junction. At that time, their program name will appear in the "My Advertisers" list in the Account Manager, and will also be removed from the temporarily deactivated list.
As your trusted third party provider, we will notify you of changes to our advertisers programs, and will do everything possible to protect your interests as a publisher.
Best regards,
Client Services
Commission Junction
 楼主| 发表于 2007-8-23 09:10:16 | 显示全部楼层
看到CJ的信我就怕怕
发表于 2007-8-23 09:10:44 | 显示全部楼层
有些广告关闭了,CJ通知你一下下。:
发表于 2007-8-23 09:10:56 | 显示全部楼层
没事儿 :
 楼主| 发表于 2007-8-23 12:57:35 | 显示全部楼层
  吓死我了 ``我看到CJ的信我真是心虚啊`
发表于 2007-8-23 15:44:23 | 显示全部楼层
安全得很。。。没有看到traffic ,IP之类的字眼就比较安全。。
发表于 2007-8-23 20:01:25 | 显示全部楼层
:  我也收到了
发表于 2007-8-23 20:42:22 | 显示全部楼层
经常有这样的信,隔三岔五的就来封 ;)
发表于 2007-8-23 20:56:48 | 显示全部楼层
呵呵。一般我几个帐号同时收到的信,心里就会比较不紧张
发表于 2007-8-23 21:20:31 | 显示全部楼层
楼上的,很镇定。
发表于 2007-8-23 23:35:07 | 显示全部楼层
呵呵,CJ就爱看看你,他不想忘记你的
发表于 2007-8-26 14:02:46 | 显示全部楼层
看到这样的信你要注意了,因为好多广告主已经到期了,每个广告主都是时间限制的,到期的你给推广也不给钱的!
发表于 2007-8-29 21:44:58 | 显示全部楼层
回复 #9 zhuanqianhao 的帖子
那你会回答吗!
GMT+8, 2025-4-17 06:36
