查看: 970|回复: 5
lunarpages.com空间使用有偿求助
发表于 2007-8-24 12:55:48 | 显示全部楼层 |阅读模式
几天前买了lunarpages.com空间,装了个hyip列表和一个dede程序,可连接数据库时老是不对,现特求助懂列表sql数据及dede安装设置的师付。本人愿以一半的空间(可加5个站)作为酬谢。
发表于 2007-8-24 13:02:10 | 显示全部楼层
帮你顶上去
发表于 2007-8-24 13:06:54 | 显示全部楼层
呵呵,其实这些很简单的,主要是把数据库设置好,有时间到我论坛去看看,看签名
 楼主| 发表于 2007-8-24 13:15:02 | 显示全部楼层
建立数据库是很简单,我认为也按要求没做错。下面是打开我的站的出错提示以及客服的答复。
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'out) as tout from hl_traffic where listing_id = 1 and date + interval 7 day > no' at line 1
客服的回复:
Hello,
This would be indicative of an error in your script. Have you verified with the provider of the script that it is php4 compliant, or if it requires any other specific features in order to run properly?
If you can provide the location where you obtained the script, as well as any script requirements it may have we may be able to verify that it is compatible with the server your site is hosted on.
发表于 2007-8-24 13:21:49 | 显示全部楼层
单独PM我,我给你看下
发表于 2007-8-24 13:30:35 | 显示全部楼层
列表要改几个文件。dede不熟悉
GMT+8, 2025-4-19 22:41
