查看: 1322|回复: 8
PP问题求助
发表于 2007-11-5 17:32:06 | 显示全部楼层 |阅读模式
原文如下:
Dear *****,
As part of our security measures, we regularly screen activity in the PayPal system. We recently contacted you after noticing an issue on your account.We requested information from you for the following reason:
A recent review of your account determined that we require some additional information from you in order to provide you with secure service.
Case ID Number: PP-***-***-***
This is a reminder to log in to PayPal as soon as possible.
Be sure to log in securely by opening a new browser window and typing the PayPal URL. Once you log in, you will be provided with steps to restore your account access. We appreciate your understanding as we work to ensure account safety.
In accordance with PayPal's User Agreement, your account access will remain limited until the issue has been resolved. Unfortunately, if access to your account remains limited for an extended period of time, it may result in further limitations or eventual account closure. We encourage you to log in to your PayPal account as soon as possible to help avoid this.
To review your account and some or all of the information that PayPal used to make its decision to limit your account access, please visit the Resolution Center. If, after reviewing your account information, you seek further clarification regarding your account access, please contact PayPal by visiting the Help Center and clicking "Contact Us".
We thank you for your prompt attention to this matter. Please understand that this is a security measure intended to help protect you and your account. We apologize for any inconvenience.
Sincerely,
PayPal Account Review Department
PayPal Email ID PP
究竟什么意思.....刚才登陆了发现没有限制帐号.究竟它想搞什么.哪位能告知?
发表于 2007-11-5 17:54:33 | 显示全部楼层
受限制了,按限制号的要求解开就可以了,该上传什么就传什么就ok
若是代激活的那就难解开了
 楼主| 发表于 2007-11-5 18:04:02 | 显示全部楼层
..........我登陆PP看了.发现并没有限制!!
发表于 2007-11-5 18:33:03 | 显示全部楼层
看看有没有冻结的款项,就算没限制,也有可能是某项调查需要你提供相关材料,一般帐户首页有提示
 楼主| 发表于 2007-11-5 19:27:44 | 显示全部楼层
原帖由 cen 于 2007-11-5 18:33 发表
一切正常..........
发表于 2007-11-5 19:32:17 | 显示全部楼层
那就是PP没问题啦,不去管它喽。
发表于 2007-11-5 19:45:13 | 显示全部楼层
要查这个交易了....你快去准备下...找到这个号码...然后自己准备咯....是不是黑PP等
 楼主| 发表于 2007-11-5 19:51:22 | 显示全部楼层
原帖由 le19754 于 2007-11-5 19:32 发表
那就是PP没问题啦,不去管它喽。
根据原文.再去查了下个人资料..一切正常...
 楼主| 发表于 2007-11-5 19:52:53 | 显示全部楼层
原帖由 binlvpj 于 2007-11-5 19:45 发表
邮件里的Case ID Number: PP-000-000-000
..............代表什么呢?去看了调解中心..没有任何需要调解的事件..
GMT+8, 2025-4-20 04:38
